Fusion Configuration Page Access
This support forum board is for questions relating to Nagios Fusion.
Ryffraff
Post by Ryffraff »
My work has recently implemented Fusion and we are working to give multiple users access to the dashboard. I noticed in a thread on the customer forums that Fusion isn't designed for multi-tenancy. We noticed that any user is able to globally change the server credentials on the configuration page (not just admins). Currently is there any way that we can limit the users from editing the configuration page while still allowing admins access?
Thanks!
Re: Fusion Configuration Page Access
Users should not be able even to see the "Configure" menu. I will be filing an internal bug report on that. This should be fixed in our next release.
Ryffraff
Post by Ryffraff »
Thank you for the prompt response! We will be looking forward for a fix.
Post by slansing »
When this is changed it will be updated in the release changelogs from the Fusion download page. Thanks for bringing this to our attention again!
