Problems when configuring and compiling ndoutils on CentOs 6
bkfrvn
Post by bkfrvn »
Hi all,
I had problems when configuring and compiling ndoutils on CentOs 6.3 64 bit (CactiEZ 0.7).
I tried with ndotils verions 1.47b and 1.52, 1.52, the problems was the same.
The config.log shows errors:
conftest.c:10:28: error: ac_nonexistent.h: No such file or directory
conftest.c:74:20: error: socket.h: No such file or directory
conftest.c:41:20: error: socket.h: No such file or directory
conftest.c:98: error: expected expression before ')' token
conftest.c:68: error: void value not ignored as it ought to be
conftest.c:103: error: expected expression before ')' token
| /* Override any GCC internal prototype to avoid an error.
while the compiling with make produced errors too. Please find the attachment file the config.log and compiling log.
Can any one help me? Thank you very much in advance!
make.log
(10.09 KiB) Downloaded 274 times
config.log
(52.49 KiB) Downloaded 286 times
sreinhardt
-fno-stack-protector
Re: Problems when configuring and compiling ndoutils on Cent
Post by sreinhardt »
From your logs, it looks like you are missing glibc-headers, and specifically socket.h, Let's check a few things and verify what might be happening. That conftest.c is specifically used in configure to verify whether everything is there, that is needed. I'm not entirely sure how you got through a proper sane make without socket.h though.
yum list installed | grep glibc
yum list installed | grep gcc
yum provides */socket.h | grep -i installed
find / -name socket.h
bkfrvn
Post by bkfrvn »
Dear Spenser,
Thank you very much for your answer!
It seems that both glibc-headers and socket.h have been installed. Please find the results of the commands you mentioned:
[root@cacti ~]# yum list installed | grep glibc
glibc.x86_64 2.12-1.132.el6 @base
glibc-common.x86_64 2.12-1.132.el6 @base
glibc-devel.x86_64 2.12-1.132.el6 @base
glibc-headers.x86_64 2.12-1.132.el6 @base
[root@cacti ~]# yum list installed | grep gcc
gcc.x86_64 4.4.7-4.el6 @base
gcc-c++.x86_64 4.4.7-4.el6 @base
libgcc.x86_64 4.4.7-4.el6 @base
[root@cacti ~]# yum provides */socket.h | grep -i installed
Repo : installed
Repo : installed
[root@cacti ~]# find / -name socket.h
/usr/include/sys/socket.h
/usr/include/bits/socket.h
/usr/include/asm/socket.h
/usr/include/linux/socket.h
/usr/include/asm-generic/socket.h
/tmp/nagios-plugins-1.4.16/gl/sys/socket.h
I tried to include the socket.h to conftest.c. However, I could not find conftest.c, i.e. find / -name conftest.c gave no answer.
Bests!
Giang.
Reason: Bump post was deleted, do not double post in that fashion, it will only place you lower on the list of "to be replied to."
Post by slansing »
And just to be clear... this is not actually a Nagios server..? You are doing this on a cacti server?
bkfrvn
Post by bkfrvn »
I compiled ndoutils on a server which both cacti and nagios is installed.
The
#make
command shown following error:
In file included from db.c:17:
../include/ndo2db.h:58: error: expected specifier-qualifier-list before ‘MYSQL’
Please refer to following topic for more details:
http://support.nagios.com/forum/viewtop ... 224#p86224
Post by slansing »
Alright, we are going to back up and try this from the start, first, what version of Nagios are you trying to install NDOutils on? We need this so we can make sure to compile the proper one.
bkfrvn
Post by bkfrvn »
I compiled Nagios version 3.5.0 . Thank you very much!
bkfrvn wrote:Thank you very much!
Is this a "Thank you very much, it worked!" or a "Thank you very much for helping so far!" sort of thank you?
bkfrvn
Post by bkfrvn »
It is a "Thank you very much for helping so far!" :)
Post by slansing »
What version of NDO are you trying to compile, and on what version of Nagios Core? Also, what version of mysql are you running on the system?
