I have a problem with monitoring one of my windows machines. When I'm trying to monitor a process Nagios says the process is down but its not.
My service definition:
host_name PW7255-01C
service_description Mmg Check
check_command check_nt!PROCSTATE!-d SHOWALL -l mmg.exe
The process name in windows task manager is: mmg.exe
Nagios status of the service: Status Information: mmg.exe: not running after 3/3 checks
All the other checks are working fine like disk space, memory usage and services.
It's a Windows 7 Enterprise machine with NSClient++
Thanks in advance /Erny
check_nt!PROCSTATE problem
Re: check_nt!PROCSTATE problem
Try defining it this way:
check_command check_nt!PROCSTATE!-l mmg.exe -d SHOWALL
