check_nrpe passing wrong arguments?
Wnt2bsleepin
Post by Wnt2bsleepin »
I have a service check for my machine that checks the disk usage. However, in the log file the arguments seem to be messed up.
Log:
Running command: /usr/local/nagios/libexec/check_disk -w 20 10 /home -c  -p
Here is my local config file for it.
check_nrpe!check_disk!20!10!/home
and here is the local NRPE command definition
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ -a "$ARG2$ $ARG3$ $ARG4$"
Here is the remote command configuration
command[check_disk]=/usr/local/nagios/libexec/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
Am I missing something?
Re: check_nrpe passing wrong arguments?
I believe you need to have the "check_nrpe" command defined as such:
$USER1$/check_nrpe -H $HOSTADDRESS$ -t 60 -c $ARG1$ $ARG2$
your check on the remote box:
command[check_disk]=/usr/local/nagios/libexec/check_disk $ARG1$
your check on the nagios box:
check_nrpe!check_disk!-a '-w 20% -c 10% -p /home'
Test it from the command line:
./check_nrpe -H <client ip> -c check_disk -a '-w 20% -c 10% -p /home'
Wnt2bsleepin
That did it. Thank you very much.
Nice to see a quick fix. I'll be locking this up now. If you have any other issues please feel free to open up another thread.
