Hi, suddenly we could not modify the homepage.
It complains
Home page modifications are currently disabled.
Can you help?
Tom
Re: Home page modifications are currently disabled.
What are you trying to change on the homepage? How did you reproduce this?
Hi on the Home Dashboard link under the Home tab, I clicked on 'change my default home page'.
A new page Home page options with Home Page Modification Settings appears, from there I pasted the Nagvis page URL there ,
for eg. Customer URL: http://xxx.xxx.xxx.xxx/nagvis/frontend/ ... show=MyMap
However , it said 'Settings Updated.Home page modifications are currently disabled.'
I tried using the Home page modification component, still no effect.
Tom
Tom
When you go to: Admin->Manage Components->Home Page Modification->Edit Settings, do you have "Allow User-Override" checkbox selected?
Hi found the problem, some one changed to drop down list of Home Page Destination to 'Default Location', Changed that to 'Custom URL' fixed it.
Thanks for your time!
Tom
Tom
