Nagios Graph error, , please support.
http://ServerIP/nagios/cgi-bin/show.cgi
No data in rrd directory /var/nagios/rrd.
http://ServerIP/nagios/cgi-bin/showconfig.cgi (Out put)
nagiosgraph configuration on 172.21.0.150
09 Dec 2013 03:18:41 IST
PERL modules
required
Carp: 1.04
CGI: 3.15
Data::Dumper: 2.121_08
File::Basename: 2.74
File::Find: 1.10
MIME::Base64: 3.07
POSIX: 1.09
RRDs: 1.3009
Time::HiRes: 1.9717
optional
GD: 2.46
nagiosgraph
ngshared.pm: ok
version: 1.4.4
nagiosgraph.conf: ok
RRD directory: ok
log file: ok
CGI log file: ok
map file: ok
Environment
AUTH_TYPE=Basic
DOCUMENT_ROOT=/var/www/html
GATEWAY_INTERFACE=CGI/1.1
HTTP_ACCEPT=image/jpeg, application/x-ms-application, image/gif, application/xaml+xml, image/pjpeg, application/x-ms-xbap, application/x-shockwave-flash, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, */*
HTTP_ACCEPT_ENCODING=gzip, deflate
HTTP_ACCEPT_LANGUAGE=en-US
HTTP_CONNECTION=Keep-Alive
HTTP_HOST=172.21.0.150
HTTP_USER_AGENT=Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; Trident/5.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; InfoPath.2)
PATH=/sbin:/usr/sbin:/bin:/usr/bin
QUERY_STRING=
REMOTE_ADDR=172.21.0.21
REMOTE_PORT=53618
REMOTE_USER=nagiosadmin
REQUEST_METHOD=GET
REQUEST_URI=/nagios/cgi-bin/showconfig.cgi
SCRIPT_FILENAME=/usr/local/nagios/sbin/showconfig.cgi
SCRIPT_NAME=/nagios/cgi-bin/showconfig.cgi
SERVER_ADDR=172.21.0.150
SERVER_ADMIN=root@localhost
SERVER_NAME=172.21.0.150
SERVER_PORT=80
SERVER_PROTOCOL=HTTP/1.1
SERVER_SIGNATURE=Apache/2.2.3 (CentOS) Server at 172.21.0.150 Port 80
SERVER_SOFTWARE=Apache/2.2.3 (CentOS)
Include Paths
/etc/nagiosgraph
/usr/lib/perl5/site_perl/5.8.8/i386-linux-thread-multi
/usr/lib/perl5/vendor_perl/5.8.8/i386-linux-thread-multi
/usr/lib/perl5/5.8.8/i386-linux-thread-multi
base configuration
/etc/nagiosgraph/nagiosgraph.conf
altautoscale=
altautoscalemax=
altautoscalemaxsep=;
altautoscalemin=
altautoscaleminsep=;
altautoscalesep=,
cgilogfile=/var/log/nagiosgraph-cgi.log
colormax=888888
colormin=BBBBBB
colors=
90d080
30a030
90c0e0
304090
ffc0ff
a050a0
ffc060
c07020
colorscheme=9
dbseparator=subdir
debug=3
expand_timeall=day,week,month,year
expand_timegroup=day
expand_timehost=week
expand_timeservice=week
geometries=650x50,800x100,1000x200,2000x100
groupdb=/etc/nagiosgraph/groupdb.conf
heartbeat=600
hostservvar=
hostservvarsep=;
javascript=/nagiosgraph/nagiosgraph.js
lasts=
lineformat=warn=LINE1,D0D050;crit=LINE1,D05050
lineformatlist=
warn=LINE1,D0D050
crit=LINE1,D05050
logarithmic=
logarithmicsep=,
logfile=/var/log/nagiosgraph.log
mapfile=/etc/nagiosgraph/map
maximums=Current Load,.*;Current Users,.*;Total Processes,.*;PLW,.*
maximumslist=
Current Load,.*
Current Users,.*
Total Processes,.*
PLW,.*
minimums=
nagiosgraphcgiurl=/nagios/cgi-bin
nogridfit=
nogridfitsep=,
perflog=/var/nagios/perfdata.log
plotas=LINE2
plotasAREA=idle,data;system,data;user,data;nice,data
plotasAREAlist=
idle,data
system,data
user,data
nice,data
plotasLINE1=load5,data;load15,data
plotasLINE1list=
load5,data
load15,data
plotasLINE2=
plotasLINE3=
plotasTICK=
resolution=600 700 775 797
rrddir=/var/nagios/rrd
rrdoptshash=
global=
showtitle=true
stack=system,data;user,data;nice,data
stacklist=
system,data
user,data
nice,data
step=1 6 24 288
stepsize=300
stylesheet=/nagiosgraph/nagiosgraph.css
timeformat_day=%H:%M %e %b
timeformat_month=Week %U
timeformat_now=%H:%M:%S %d %b %Y %Z
timeformat_quarter=Week %U
timeformat_week=%e %b
timeformat_year=%b %Y
timegroup=day,week,month
timehost=day,week,month
timeservice=day,week,month
withmaximums=
HTTP=1
PING=1
withmaximumssep=,
withminimums=
HTTP=1
PING=1
withminimumssep=,
xff=0.5
map rules
/output:CHECK_NRPE: Socket timeout/
and return ('ignore');
/output:NRPE: Unable to read output/
/output:CRITICAL - Socket timeout after/
/output:CRITICAL - Plugin timed out after/
/output:NTP CRITICAL: No response from NTP server/
/output:Connection refused/
/output:.*plugin may be missing/
/output:.*Host Unreachable/
/output:Connection to \S+ failed/
/output:.*timed out waiting for/
/perfdata:.*udpInDatagrams=(\d+), udpOutDatagrams=(\d+), udpInErrors=(\d+), tcpActiveOpens=(\d+), tcpPassiveOpens=(\d+), tcpAttemptFails=(\d+), tcpEstabResets=(\d+), tcpCurrEstab=(\d+), tcpOutDataBytes=(\d+), tcpInDataBytes=(\d+), tcpRetransBytes=(\d+)/
and push @s, [ 'udp',
[ 'InPkts', DERIVE, int $1/300 ],
[ 'OutPkts', DERIVE, int $2/300 ],
[ 'Errors', DERIVE, int $3/300 ] ],
[ 'tcp',
[ 'ActOpens', DERIVE, int $4/300 ],
[ 'PsvOpens', DERIVE, int $5/300 ],
[ 'AttmptFails', DERIVE, int $6/300 ],
[ 'OutBytes', DERIVE, int $9/300*8 ],
[ 'InBytes', DERIVE, int $10/300*8 ] ];
(/output:NTP/ and /perfdata:\s*offset=/)
or
(/output:NTP.*Offset ([-.0-9]+).*jitter ([-.0-9]+).*stratum (\d+)/
and push @s, [ 'ntp',
[ 'offset', GAUGE, $1 ],
[ 'jitter', GAUGE, $2/1000 ],
[ 'stratum', GAUGE, $3+1 ] ])
or
(/output:NTP.*Offset ([-.0-9]+) secs/
[ 'offset', GAUGE, $1 ] ]);
/output:.*uptime is.*?([.\d]+)\sDays/
and push @s, [ 'days',
[ 'data', GAUGE, $1 ] ]
or (/output:.*uptime is.*?([.\d]+)\sHours/
[ 'data', GAUGE, $1/24 ] ])
or (/output:.*uptime is.*?([.\d]+)\sMinutes/
[ 'data', GAUGE, $1/1440 ] ]);
(/output:PROCS.*?(\d+) processes\n/ or
/output:PROCS.*?(\d+) processes with STATE = RSZDT/)
and push @s, [ 'procs',
[ 'data', GAUGE, $1 ] ];
/output:PROCS.*?(\d+) processes with STATE = Z/
and push @s, [ 'zombies',
(! @s || $#s < 0) and /perfdata:(.+)/ and do {
my $pd = $1;
while ( $pd =~ s/([^=]+)=(\S+)// ) {
my ($n,$y) = ($1,$2);
next if (!defined $n || $n eq q());
my ($v,$u,$x) = $y =~ /([-0-9.]+)([^;]*)(.*)/;
next if (!defined $v || $v eq q());
my ($w,$c,$min,$max);
if (defined $x && $x ne q()) {
$x =~ s/^;//;
($w,$c,$min,$max) = split /;/, $x;
$n =~ s/^\s+//g;
$n =~ s/\s+$//g;
$n =~ s/^\'//g;
$n =~ s/\'$//g;
$n =~ s/\'\'/\'/g;
my ($wlo, $whi);
if (defined $w && $w ne q()) {
if ($w =~ /([-0-9.]+):([-0-9.]+)/) {
$wlo = $1; $whi = $2; $w = q();
} elsif ($w =~ /([-0-9.]+):/) {
$whi = $1; $w = q();
} elsif ($w =~ /:([-0-9.]+)/) {
$wlo = $1; $w = q();
my ($clo, $chi);
if (defined $c && $c ne q()) {
if ($c =~ /([-0-9.]+):([-0-9.]+)/) {
$clo = $1; $chi = $2; $c = q();
} elsif ($c =~ /([-0-9.]+):/) {
$chi = $1; $c = q();
} elsif ($c =~ /:([-0-9.]+)/) {
$clo = $1; $c = q();
my $t = 'GAUGE';
if (defined $u) {
my $mult = 1;
if ($u eq 'c') {
$t = 'DERIVE';
} elsif ($u eq 's') {
$mult = 1;
} elsif ($u eq 'ms') {
$mult = 1 / 1_000;
} elsif ($u eq 'us') {
$mult = 1 / 1_000_000;
} elsif ($u eq 'B') {
$mult = 1;
} elsif ($u eq 'KB' || $u eq 'K' || $u eq 'kB') {
$mult = 1024;
} elsif ($u eq 'MB' || $u eq 'M' || $u eq 'mB') {
$mult = 1024 * 1024;
} elsif ($u eq 'GB' || $u eq 'G' || $u eq 'gB') {
$mult = 1024 * 1024 * 1024;
} elsif ($u eq 'TB' || $u eq 'T' || $u eq 'tB') {
$mult = 1024 * 1024 * 1024 * 1024;
} elsif ($u eq 'PB' || $u eq 'P' || $u eq 'pB') {
$mult = 1024 * 1024 * 1024 * 1024 * 1024;
if ($mult != 1) {
$v *= $mult;
if ( defined $w && $w ne q()) { $w *= $mult; }
if ( defined $c && $c ne q()) { $c *= $mult; }
if ( defined $min && $min ne q()) { $min *= $mult; }
if ( defined $max && $max ne q()) { $max *= $mult; }
if ( defined $wlo && $wlo ne q()) { $wlo *= $mult; }
if ( defined $whi && $whi ne q()) { $whi *= $mult; }
if ( defined $clo && $clo ne q()) { $clo *= $mult; }
if ( defined $chi && $chi ne q()) { $chi *= $mult; }
my @x;
push @x, [ 'data', $t, $v ];
push @x, [ 'warn', $t, $w ] if defined $w && $w ne q();
push @x, [ 'crit', $t, $c ] if defined $c && $c ne q();
push @x, [ 'min', $t, $min ] if defined $min && $min ne q();
push @x, [ 'max', $t, $max ] if defined $max && $max ne q();
push @x, [ 'warn_lo', $t, $wlo ] if defined $wlo && $wlo ne q();
push @x, [ 'warn_hi', $t, $whi ] if defined $whi && $whi ne q();
push @x, [ 'crit_lo', $t, $clo ] if defined $clo && $clo ne q();
push @x, [ 'crit_hi', $t, $chi ] if defined $chi && $chi ne q();
push @s, [ $n, @x ];
labels
labelfile is not defined
host settings
hostdb is not defined
service settings
servdb is not defined
group settings
PING=host1,PING&db=ping,rta
PING=host1,PING&db=ping,losspct
PING=host2,PING&db=ping,losspct
PING=host3,PING&db=ping,losspct
PING=host4,PING&db=ping,rta
PING=host4,PING&db=ping,losspct
PING=host5,PING&db=ping,losspct
Customer1=gateway1,PING&db=ping,rta
Customer1=host1,PING&db=ping,rta
Customer1=host1,HTTP&db=http
Customer1=mail1,SMTP: mailq&db=mailq,qsize
Customer2=gateway2,PING&db=ping,rta
Customer2=host2,PING&db=ping,rta
Customer2=host2,HTTP&db=http
Mail Servers=mail00,PING&db=ping,losspct
Mail Servers=mail00,SMTP: mailq&db=mailq,qsize
Mail Servers=mail01,PING&db=ping,losspct
Mail Servers=mail01,SMTP: mailq&db=mailq,qsize
Web Servers=http00,PING&db=ping,losspct
Web Servers=http00,HTTP&db=http
Web Servers=http01,PING&db=ping,losspct
Web Servers=http01,HTTP&db=http
Web Servers=http02,PING&db=ping,losspct
Web Servers=http02,HTTP&db=http
Backup=backup0,net&db=net,bytes-trasmitted&db=net,bytes-received
Backup=backup0,Partition: /&db=diskgb
Backup=backup1,net&db=net,bytes-trasmitted&db=net,bytes-received
Backup=backup1,Partition: /&db=diskgb
data sources
datasetdb is not defined
RRD options
rrdoptsfile is not defined
contents of config directory
/etc/nagiosgraph:
total 200
drwxr-xr-x 2 root root 4096 Dec 9 03:12 .
drwxr-xr-x 141 root root 12288 Dec 9 02:40 ..
-rw-r--r-- 1 root root 879 Dec 9 02:30 access.conf
-rw-r--r-- 1 root root 873 Dec 9 02:30 datasetdb.conf
-rw-r--r-- 1 root root 2251 Dec 9 02:30 groupdb.conf
-rw-r--r-- 1 root root 1446 Dec 9 02:30 hostdb.conf
-rw-r--r-- 1 root root 1828 Dec 9 02:30 labels.conf
-rw-r--r-- 1 root root 9836 Dec 9 02:30 map
-rw-r--r-- 1 root root 14340 Dec 9 02:38 nagiosgraph.conf
-rw-r--r-- 1 root root 793 Dec 9 02:30 nagiosgraph_de.conf
-rw-r--r-- 1 root root 865 Dec 9 02:30 nagiosgraph_es.conf
-rw-r--r-- 1 root root 935 Dec 9 02:30 nagiosgraph_fr.conf
-rw-r--r-- 1 root root 107992 Dec 9 02:30 ngshared.pm
-rw-r--r-- 1 root root 660 Dec 9 02:30 rrdopts.conf
-rw-r--r-- 1 root root 480 Dec 9 02:30 servdb.conf
contents of RRD directory
/var/nagios/rrd:
total 8
drwxr-xr-x 2 nagios root 4096 Dec 9 02:39 .
drwxr-xr-x 3 root root 4096 Dec 9 02:39 ..
