I'm trying to configure hostescalation and i'm having trouble understanding how to get notifications to go out at the right time. What I want is when a host goes down a notification is sent out by email and then it resends the notification even 1440 minutes. I've gotten this step done and working. But then I want a text notification to go out 15 minutes after the first email to escalate the outage. I've successfully gotten the email and text to go out but they send at the same time instead of 15 minutes after the email. Below is what I've put together, any assistance/Tips would be greatly appreciated.
name generic-printer
use generic-host
check_period 24x7
check_interval 5
retry_interval 1
max_check_attempts 10
notification_period workhours
notification_interval 1440
notification_options d,r
contact_groups admins
register 1
define hostescalation {
host_name HP425-2
hostgroup_name network-printers
contact_groups paging
first_notification 1
last_notification 1
notification_interval 15
Thank you in advance!
Help configuring HostEscalation
Re: Help configuring HostEscalation
This might not be the best use of escalations, what you should look at doing is setting up two different contacts, one for the email portion (every 24 hours) and the other for your SMS messaging, then you can define each contacts settings in their configuration individually.
mr_snelson
I have set up two different contacts and two different contact groups. Where in the define host portion i have the contact group set to admins, which sends the email notification and then in the host escalation area i have the contact group paging which sends out the text. I am new to nagios so correct me if i'm wrong, but i figured i would have the host escalation potion que my contact group to send out the notification when needed. I just cant figure out how to get the notification send out at the right now.
the notification_interval is how frequently you are re-notified
you would need to set the notification_interval of the service to be 15, then set
host_name HP425-2
first_notification 2
last_notification 2
mr_snelson
From what I understand changing the Notification_interval to 15 would then have an email sent every 15 minutes. I want an email to be sent once a day, hence the 1440, and then i want an escalation text sent out 15 minutes after the email is reported down. We don't want tons of emails sent out over an over again.
The section
means that the first escalation notification will go out on the second regular notification, and the last one is also the second regular notification. Only one escalation notification will be sent out in this case.
last_notification 2
