Had a drive issue seem to have lost all configurations.
Im not 100% sure what happed but on my nagios xi install we started to get errors and when I came into work one Saturday the system would not boot up giving hard disk errors. Got that resolved and the server back up but when i tried to login was getting incorrect password errors so I decided to recover from a backup which after this I was now able to login using my old login information but now the only thing showing up in the hosts/services is the local host none of my hosts are showing up now?
tonyyarusso
Re: Had a drive issue seem to have lost all configurations.
How old was the backup? What format was it? (Full disk, file level, database dump) Can you see anything besides localhost in the `nagiosql` database in MySQL?
The backup was from backup script in nagios xi I modified it to save everything to a different drive so when i look at the zip file its 16.6 MB and it says its from december 2010 which im not sure if thats right even if it is the configuration hasn't changed since then.
As for looking through the database I'm not that good with sql But in the nagiosql database and in the tbl_host table I have this Im not sure if this is the correct table?
SELECT * FROM tbl_host;
| id | host_name | alias | display_name | address | parents | parents_tploptions | hostgroups | hostgroups_tploptions | check_command | use_template | use_template_tploptions | initial_state | max_check_attempts | check_interval | retry_interval | active_checks_enabled | passive_checks_enabled | check_period | obsess_over_host | check_freshness | freshness_threshold | event_handler | event_handler_enabled | low_flap_threshold | high_flap_threshold | flap_detection_enabled | flap_detection_options | process_perf_data | retain_status_information | retain_nonstatus_information | contacts | contacts_tploptions | contact_groups | contact_groups_tploptions | notification_interval | notification_period | first_notification_delay | notification_options | notifications_enabled | stalking_options | notes | notes_url | action_url | icon_image | icon_image_alt | vrml_image | statusmap_image | 2d_coords | 3d_coords | use_variables | name | active | last_modified | access_rights | config_id |
| 1 | localhost | localhost | | 127.0.0.1 | 0 | 2 | 0 | 2 | NULL | 1 | 2 | | NULL | NULL | NULL | 2 | 2 | 0 | 2 | 2 | NULL | 0 | 2 | NULL | NULL | 2 | | 2 | 2 | 2 | 0 | 2 | 0 | 2 | NULL | 0 | NULL | | 2 | | | | | | | | | | | 1 | | 1 | 2010-12-04 09:37:24 | NULL | 1 |
1 row in set (0.00 sec)
Is this the correct table? any ideas on this do I just have to start over?
It looks like the only host in the table is localhost. Is that even showing up? That table *should* be populated with all of your hosts.
Nicholas Scott
Yes local host is the only host showing up. I have the nagios backup file which is in zip format is there anything I need to look for in there maybe manually copy a file over to make sure it goes to the correct location?
Do you have any of your old configuration snapshots, or config backups of your /usr/local/nagios/etc directory? If you do, you could import the object configuration files back into the Core Config Manager. Right now you're definitely missing everything but localhost.
Bah I looked there and its a no go. I looked through the zip file that the backup process makes and the only thing listed was local host again. Not sure why my backup only had local host this is just the default backup script that i used in nagiosxi does it only backup local host data and i need to modify it to do more?
You shouldn't need to. Do you have a /etc/nagiosql/backup ?
Nicholas Scott
Yes I have that folder but inside there is a hosts and services folder which are empty.nscott wrote:You shouldn't need to. Do you have a /etc/nagiosql/backup ?
