DB Monitoring using XI
lafargeuser
Is this possible using Nagios XI, I want to monitor MS SQL Database e.g. If transaction log file cross 5 GB Nagios should send an alert.
Re: DB Monitoring using XI
Can you check the transaction log size with a query?
lafargeuser
How do I do that ? Is this requirement feasible using Nagios.
Something like this can be used with the MSSQL Query wizard, replacing YOURDBNAMEHERE with the DB name
Credit:
http://stackoverflow.com/questions/1983 ... mmatically
SELECT (size * 8.0)/1024.0 AS size_in_mb, CASE WHEN max_size = -1 THEN 9999999 ELSE (max_size * 8.0)/1024.0 END AS max_size_in_mb FROM YOURDBNAMEHERE.sys.database_files WHERE data_space_id = 0http://stackoverflow.com/questions/1983 ... mmatically
