Nagios Crashed - DB Error - Root 100%
rredmond
Post by rredmond »
Nagios XI crashed over the weekend due to what I was told was a database error. I was able to reboot the machine and putty in and quickly saw root full. Deleted logs, cleared messages but only got 99%. Noticed /var/log/messages.log was huge! Cleared it but it filled back up almost immediately. Any ideas???????
Randy J Redmond
[email protected]
rredmond
Re: Nagios Crashed - DB Error - Root 100%
Post by rredmond »
Well, the more I dig it looks like DB corruption in MySql....and its fighting my attempts to repair....any help would be much appreciated
abrist
Red Shirt
Post by abrist »
XI provides a script for repairing mysql:
/usr/local/nagiosxi/scripts/repairmysql.sh nagios
/usr/local/nagiosxi/scripts/repairmysql.sh nagiosql
rredmond
Post by rredmond »
Well, I do not have that script in that directory or anywhere else that I could find! I tried repairing mysql database nagios which worked until sometime last night at which time it must have corrupted again and once again filled the drive. Please advise...................Randy
rredmond
Post by rredmond »
t 1Im looking at some of the mail messages Im getting and Im now seeing:
SNMPGET Problem for ifInOctets.1 ifOutOctets.1 on [email protected]
Received SNP response error code
error status: noSuchName
SNMPv1_Session (remote host: "172.19.1.2" [172.19.1.2].161)
over and over again for different ips
172.19.1.2 is our gateway router and Im told is accepting SNMP requests.......PLEASE advise!
Randy
rredmond
Post by rredmond »
PostGres logs also large.....told we have to Vacuum? logs are indeed huge....very confused
First, try to delete as many old logs as you can in "/var/log" directory and sub-directories. Check what you have in the "/tmp". You can probably delete some old backups that you don't need in "/store/backups/". After you clear some room, run the database repair script:
./repairmysql.sh nagios
./repairmysql.sh nagiosql
Then add some disk space. If this is a VM, you can follow the steps, outlined in this document:
http://assets.nagios.com/downloads/nagi ... M_Disk.pdf
Let me know if this helped.
