error while performing http checks
Team,
We are reciving "HTTP CRITICAL - Error on receive" while performing http checks.Url is accessible and also reachable from nagios server.
Can you please let us know how to fix it.
Re: error while performing http checks
Can you give us an example of the full command? Do you know if the website uses chunked encoding?
Below is example
./check_http -S --ssl -c 15 -t 15 -f follow -H carrierlogistics.external.xerox.com -v
GET / HTTP/1.0
User-Agent: check_http/v2053 (nagios-plugins 1.4.13)
Connection: close
Host: carrierlogistics.external.xerox.com
Not sure of the second part (chunked encoding).
GET / HTTP/1.0
Connection: close
Can you try using the -I switch instead of -H?
ravish78 wrote:./check_http -S --ssl -c 15 -t 15 -f follow -I carrierlogistics.external.xerox.com -v
I get same output
GET / HTTP/1.0
Connection: close
Even from other nagios server i receive same error.
GET / HTTP/1.0
User-Agent: check_http/v1991 (nagios-plugins 1.4.12)
Connection: close
GET / HTTP/1.0
Connection: close
GET / HTTP/1.0
Connection: close
sreinhardt
- -fno-stack-protector
I'm wondering if this is an IIS7 issue. I have the exact same things happening even if I add a user agent string or alter the timeout. Additionally, when loading via a web browser, it never finishes loading the page, I believe this may have something to do with the close statement you are getting from the server in check_http
Ravish, lets try this with the newest plugins build:
Did this check work?
EDIT, you should be able to just use -H as well:
cd /tmp
wget https://github.com/nagios-plugins/nagios-plugins/archive/master.zip
yum install -y unzip
unzip master
cd nagios-plugins-master/
tools/setup
./configure
make all
cd plugins
./check_http -S --ssl -c 15 -t 15 -f follow -I carrierlogistics.external.xerox.comEDIT, you should be able to just use -H as well:
./check_http -S --ssl -c 15 -t 15 -f follow -H carrierlogistics.external.xerox.comFormer Nagios employee
sreinhardt
Note after abrists post, if it works you would need to move the new plugin to the libexec folder.
All set to use without any changes to XI or your current commands!
mv /usr/local/nagios/libexec/check_http /usr/local/nagios/libexec/check_http.old
cp /tmp/nagios-plugins-master/plugins/check_http /usr/local/nagios/libexec/Nagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
It works with new plugin.
What is the difference between old and new.
