Dear Team, pls confirm the maximum time that can be set for pinging one host in Nagios.
regards
Pinging time
Re: Pinging time
Do you mean using the check_ping plugin with the -t flag? I don't believe there is a limit, you can add the -t flag and specify however many seconds you want.
One thing to note, if you have many machines that aren't responding, it will not return a response to Nagios until the number of seconds set by -t
This could cause high load if you have a very high time.
Additionally, you cannot exceed the time in seconds you have specified in nagios.cfg for these values
host_check_timeout=30
service_check_timeout=60
