Linux Configuration file - Location and Name
Kimba7070
Post by Kimba7070 »
What is the location of Nagios xi client configuration file on Linux ? and what is the name of the file
Re: Linux Configuration file - Location and Name
You'll need to be a little more specific than that as there are several config files. What are you trying to do?
Most configs will be located in /usr/local/nagios/etc assuming a standard install.
Post by 455157 »
Is your goal to manually maintain configs on the CLI, outside of the GUI/Core Config Manager?
If so, this would be done in:
/usr/local/nagios/etc/static
Configs stored there are not overwritten when you Apply Config from the GUI:
http://assets.nagios.com/downloads/nagi ... _Files.pdf
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Good information 455157, thanks for helping them out!
