Server Move - VM Question
Pilly170
Post by Pilly170 »
I have moved nagios VM from a hyper-V to Xenserver.
All looks ok, It boots, I can login. but the network doesnt seem to be working.
I was using this:
http://exchange.nagios.org/directory/Tu ... on/details
I got to ifdown eth0
Says "Device Eth0 has mac address xxxxxxx, instead of configured address xxxxxx . ignoring
Any ideas how to overcome?
abrist
Red Shirt
Re: Server Move - VM Question
Post by abrist »
You may need to alter the network settings in centos. What are the contents of the ifcfg network config files?
cat /etc/sysconfig/network-scripts/ifcfg-eth*
You may need to remove the mac address from the files. If this server has more than one nic, it may be assigning the nics in a different order under xen than it did under hyper-v.
Pilly170
Post by Pilly170 »
So I assume I have to remove the hardware entry... any ideas?
Pilly170
Post by Pilly170 »
I edited the file. rebooted and it seems to work.
abrist
Red Shirt
Post by abrist »
Try removing/commenting out the HWADDR line by adding a '#' to the front of the line. Afterwards, reboot the server or restart networking.
