Missing Tactical Overview View
dsydnor
Post by dsydnor »
I believe I may have inadvertently deleted my default "Tactical Overview" view that was created from the demo install. How can I add this back?
Re: Missing Tactical Overview View
It should be under the Quick View section in the Home menu. (Click Blue Triangle to expand if it is closed).
It shouldn't be possible to remove this without severely crippling your XI machine as it is part of a Core component
dsydnor
Post by dsydnor »
It is under Quick View but should/can it be available under "My Views" as well?
abrist
Red Shirt
Post by abrist »
Yes. Go to the tactical overview page. In the upper right hand corner, you will see 2 overlapping rounded corner rectangular boxes (next to the red help ?). The title text should read "add to my views". Click this and add it.
dsydnor
Post by dsydnor »
That did it! Thanks.
Always nice to see a quick fix! Gonna lock this topic up now. Feel free to open a new one if you have any other questions.
