SSL in Network Analyzer
- snapon_admin
I didn't see any documentation on implementing SSL into NNA. If I just missed it would someone be able to point me in the right direction for that? Otherwise, it seems like the process would be similar, if not exactly the same as that of XI. If that's the case I can just follow that guide, just wanted to make sure before I start playing with things.
Re: SSL in Network Analyzer
This is not currently available, however I am going to put in a feature request for it. The reason it's not quite ready (though many steps would be identical to Nagios XI's documentation) is that there is currently not a spot in the web interface to switch over the mysql server protocol, or the web address that the NNA web UI uses to resolve to, which would need to be switched to https.
- snapon_admin
Makes since to me (yay, new software!!
) You can go ahead and lock this one then, I'll just keep my eyes on the release notes and see when this gets added in the future. Thanks!
Sounds good! Yep, new software! Yay! Haha, I put the feature request in, it will no doubt make it in at some point.
