Hello fellow Nagiosers...recently got SNMP traps working in Nagios and was trying to figure out the best way to handle alerts that do not get cleared via clear traps. Is there some sort of auto clear time property that can be set so the alert will just clear on its own after x amount of seconds?
Thanks to all for your help.
SNMP Trap timer
sreinhardt
- -fno-stack-protector
Re: SNMP Trap timer
There is not, about the only way I could think to do this, would be to use freshness checks and check_dummy to submit an ok state after x period of time.
