1. What version of Nagios XI are you using? 2012R2.8c
2. Linux Distribution and version? CentOS release 6.5 (Final)
3. 32 or 64bit? 64bit
4. VMware Image or Manual Install of XI? Manual Install of XI
5. Are there special configurations on your system? No
Short version:
Please tell me how to properly escape this password: 123password^%$
Full detail:
I can run the following command from the command line no problem...
./check_wmi_plus.pl -H 10.0.0.10 -u 'NACORP/svc-nagios' -p '123password^%$' -m checkservice -a 'W3SVC'
OK - Found 1 Services(s), 1 OK and 0 with problems (0 excluded). 'World Wide Web Publishing Service' (W3SVC) is Running.|'Total Service Count'=1; 'Service Count OK State'=1; 'Service Count Problem State'=0; 'Excluded Service Count'=0;Code: Select all
$USER1$/check_wmi_plus.pl -H $HOSTADDRESS$ -u $ARG1$ -p $ARG2$ -m $ARG3$ $ARG4$
$ARG1$ = 'NACORP/svc-nagios'
$ARG2$ = '123password^%$'
$ARG3$ = checkservice
$ARG4$ = -a 'W3SVC'Code: Select all
/usr/local/nagios/libexec/check_wmi_plus.pl -H 10.0.0.10 -u 'NACORP/svc-nagios' -p '123password\^%\$' -m checkservice -a 'W3SVC'
OUTPUT: UNKNOWN - The WMI query had problems. You might have your username/password wrong or the user's access level is too low. Wmic error text on the next line.
[librpc/rpc/dcerpc_util.c:1290:dcerpc_pipe_auth_recv()] Failed to bind to uuid 4d9f4ab8-7d1c-11cf-861e-0020af6e7c57 - NT_STATUS_NET_WRITE_FAULT
[librpc/rpc/dcerpc_connect.c:790:dcerpc_pipe_connect_b_recv()] failed NT status (c0000022) in dcerpc_pipe_connect_b_recv
[wmi/wmic.c:196:main()] ERROR: Login to remote object.
NTSTATUS: NT_STATUS_ACCESS_DENIED - Access deniedI read in another post that this might only be a limitation of the "Test Commands" button in CCM (scottwilkerson).
However, if I apply the configuration and check the Service Status Detail...
NTSTATUS: NT_STATUS_ACCESS_DENIED - Access deniedCode: Select all
check_xi_service_wmiplus!'NACORP/svc-nagios'!'123password^%$'!checkservice!-a 'W3SVC'!!!!Please tell me how to properly escape this password: 123password^%$
