Scheduled downtime report
I have an executive that wants to see a report of scheduled downtime history, and in that report they wish to see who and when it was scheduled, so they can match it up with the requests for changes to the production environment. How would I go about this? I have looked through every report option nagios contains (built-in) and through the exchange (http://exchange.nagios.org/directory) to find no way to go about this.
Re: Scheduled downtime report
Hmm, we do not currently have the ability to do this. What you could do, (and this is ugly) is if you have Enterprise edition you could schedule the Scheduled Downtime page as a recurring report. You would use the button shown below in the top right of the blue menu bar to do it.
I have seen that and I do have the enterprise edition, but wouldn't that only return information if there are any scheduled downtimes at the time the report kicks off?
Correct, it would only be current downtime that is planned to be set in the future, or if used in the Recurring downtime section, it would show all recurring downtime. This can also be pulled from the nagios log by grepping for downtime:
Though, that would not be pulled in a report in the web interface, unless you created one to pull that information into a report.
[1392307970] HOST DOWNTIME ALERT: localhost;STARTED; Host has entered a period of scheduled downtimeRe: Scheduled downtime report
Unfortunately that will not work for me, thank you anyways though, I have placed a feature request in Mantis (http://tracker.nagios.com/view.php?id=501).
You can get a list of previous scheduled downtimes in the event log. Go to Home --> event log --> set your timeframe and then search for 'DOWNTIME'.
Yes thank you, however it does not state who or what the comment was for the scheduled downtime.
It should. For example, I ran a test of downtime with a comment. The event log shows:
Scheduled Downtime Start2014-02-13 10:11:36HOST DOWNTIME ALERT: localhost;STARTED; Host has entered a period of scheduled downtime
External Command2014-02-13 10:11:36EXTERNAL COMMAND: SCHEDULE_HOST_DOWNTIME;localhost;1392315063;1392322263;1;0;7200;Nagios Administrator;This is my comment
How are you getting it then because all I see in addition to who was notified is:
2014-02-12 11:00:00HOST DOWNTIME ALERT: host01;STARTED; Host has entered a period of scheduled downtime
Are you configuring recurring downtime, or just a one-off scheduled downtime?
