Upgadeing to 1.1H did not fix Email Notification in 1.1G '4u
mmestnik
Post by mmestnik »
Sorry the title has a length limit.
If after upgrading to 1.1H your notifications are still not being sent, post a message here.
Thank you!
gary_ford
Re: Upgadeing to 1.1H did not fix Email Notification in 1.1G '4u
Post by gary_ford »
didnt work for me - had to use the code mentioned in the other thread
mmestnik
Post by mmestnik »
Thank you Gary, I just hope that no one else experiences this.
gary_ford
Post by gary_ford »
maybe my upgrade didnt work.. as the version number online stayed at 1.1g. I have just downloaded the package again and run the upgrade for a second time and now it reads 1.1h correctly.
However - notifications are not working again.
so to recap.
1.1f working
1.1g notifications broken
1.1h - didnt change version info and notification still not working
applied patch as per code - notifications now work
upgrade to 1.1h again - the version has changed but the notificationa are not working again
I am happy to stay here for a while if you wish to have any of my logs etc.. let me know.
mmestnik
Post by mmestnik »
Earlier reports about this being the case from us may have been presumptuous. We are still looking into this.
I'm still looking for other reports.
gary_ford
Post by gary_ford »
more testing from me..
ok upgrading to 1.1h has enabled email alert notification. The thing that doesnt work is the send custmo notification... not sure what different elements these require but if i apply the code fix then the custom notifications will start working for me.
pbernardi
Post by pbernardi »
I am on 1.1H and the test notification works, but monitors are not sending off notifications when they should be, nor do the custom notifications work. The patch from the other thread returns errors when I tried to apply it.
patching file /usr/local/nagiosxi/cron/eventman.php
patch: **** malformed patch at line 8: //define("BACKEND",1);
and
Hunk #1 FAILED at 9.
1 out of 1 hunk FAILED -- saving rejects to file /usr/local/nagiosxi/cron/eventman.php.rej
Because I downloaded the VM just a couple days ago it came with 1.1H and I cannot roll back to any previous version.
mmestnik
Post by mmestnik »
We can get you a link to a 1.1e VM that can be upgraded using another link to 1.1f. Ask [email protected].
As for Notifications it's something we've tested and re-tested. One note is that the nagiosadmin contact may need it's template adjusted to be the xi_* for the settings in NagiosXI to take effect. If you are using the other template then you will need to update the contact to contain the correct email address.
The patch will not apply and thus does not apply to 1.1g.
pbernardi
Post by pbernardi »
Actually, adding the nagios xi template to the nagios admin account seems to have done the trick.
mmestnik
Post by mmestnik »
Gary, does this correct it for you as well?
