im working with mysql_health_check now and it's working fine from command and when i've but when add it to config it does not
and shows error
Critical "Return code of 13 is out of bounds") is this related to enable_embedded_perl removal from core4
and i test this plugin with core3 and it's working fine with the same configuration
perl plugins with core4
Re: perl plugins with core4
Yes, the internal perl implementation was removed in core 4, and yes, it is most likely the cause of your issue. You will need to make sure perl is installed on the host in question, and you will need to add "/usr/bin/perl" to the beginning of the check's command line. For example:
You can discover which path to perl to use with:
command_name fancy_perl_plugin_check
command_line /usr/bin/perl $USER1$/fancypants_plugin.pl
}Code: Select all
which perlFormer Nagios employee
thanks but the problem still the same
Feb 17 13:22:00 Nagios nagios: Warning: Return code of 13 for check of service 'mysql uptime' on host 'server.XXX.com' was out of bounds.
and i've tested the plugin with core3 and it's working fine with the same command line configuration
and also i've tested it to run command throught nrpe and it's woring fine
but the problem still the same with core4
It could also be a permissions issue. what are the permissions on the plugin? Can you run the check from the cli as user "nagios"?
it's ok when i run the command from the command line as nagios user
[nagios@Nagios libexec]$ /usr/bin/perl mysql_health_check.pl -H localhost -u XXXX -p XXXX -m varcomp --expression='Threads_connected/max_connections * 100' --comparison='>80'
mysql_varcomp OK - Comparison check passed: (Threads_connected/max_connections * 100) >80 = 0.66
Can you post the full command and service check definitions?
