Unable to open Configuration snapshots
HI Team,
When I try to view/download the configuration snapshots(Configure->Core Config Manager->Configuration Snapshots) on nagios I get a message 'Internet Explorer Cannot display the webpage' Please suggest.
Re: Unable to open Configuration snapshots
Have you tried it with a different browser?
I have tried it on firefox and I cant view the file there as well. I get a message saying page cant be displayed. We are using Nagios XI 2012R2.8c
Okay, go try to view a snapshot again and right after you do run the following on the server command line:
tail -20 /var/log/httpd/error_log
Be sure to censor any sensitive information.
This is all I see when I run that command.
Please suugest the path of this config snapshot on the nagios server as we have a config error now and without the info in the file we cant move forward. Please help.
i Have done the required changes and it is still the same..!!
we have the run the command - tail -20 /var/log/httpd/error_log - again. results in attched file
What is the output of:
cat /etc/php.ini | grep 'timezone'Re: Unable to open Configuration snapshots
This is the Output I get
; Defines the default timezone used by the date functions
; http://www.php.net/manual/en/datetime.c ... e.timezone
date.timezone = UTC
date.timezone = UTC
I would recommend disabling selinux by running the following command:
Next, open the "/etc/php.ini" file and enter the correct timezone on the following line:
You can view the available timezones here:
http://us3.php.net/timezones
You can also review this document:
http://assets.nagios.com/downloads/nagi ... m_Time.pdf
Restart apache:
setenforce 0Code: Select all
date.timezone =http://us3.php.net/timezones
Restart apache:
service httpd restartBe sure to check out our Knowledgebase for helpful articles and solutions!
