snmp traps with Nagios
bbzz
Post by bbzz »
I managed to get Nagios collect snmp traps with snmptt. This works well. However, is there a way to have a listing of all snmp traps, not just the last one received?
In other words, if a host sends a couple of traps, Nagios only has one field for that service per host, so you end up missing previos traps from that host.
Is there a way to have a table structure which will list all traps on order they are received?
Kind Regards
Re: snmp traps with Nagios
Post by slansing »
If your traps are causing state changes, or alterations "which they should be since they were triggered by this" they should show up under the Reports > Alerts section, or the event log. Though it is not a feature of nagios core, you can view past host/service checks in Nagios XI.
