Guys,
When I use the "Backend API URL"
and I get a list of error hosts: "/nagiosxi/backend/?cmd=gethoststatus..."
and a list of error services: "/nagiosxi/backend/?cmd=getservicestatus..."
and a list of servicegroups: "/nagiosxi/backend/?cmd=getservicegroups..."
I don't see how I can connect the service issue
with the service group.
What am I missing?
Thanks in advance,
GKH
Need service to servicegroup link
Re: Need service to servicegroup link
You can try: "/nagiosxi/backend/?cmd=getservicegroupmembers...". I'm not sure if this is what you are looking for.
I gotcha. Use a 2 level lookup.
Get the "getservicestatus", get the service that is failing and then
check it against "getservicegroupmembers".
That should work.
Thank you!
That should work.
Thank you!
sreinhardt
- -fno-stack-protector
Glad it should work for you! If you have further troubles let us know, otherwise letting us know its all set would be appreciated too!
We can close this ticket. I was able to get the info from both URLs.
Thank you!
Thank you!
