nagios snmp
nshahorchard
nagios snmp
Okay, So i went ahead and install the check_snmp plugin. I downloaded some of the 3rd party MIB files from the respective websites. Once I've downloaded them, I uploaded them into /usr/share/snmp/mibs directory. Here is some examples of the OIDs provided:
SUPERMICRO-HEALTH-MIB smHealthMIB 1.3.6.1.4.1.10876.2.1
SUPERMICRO-HEALTH-MIB smHealthObjects 1.3.6.1.4.1.10876.2.1.1
SUPERMICRO-HEALTH-MIB smHealthMonitorTable 1.3.6.1.4.1.10876.2.1.1.1
SUPERMICRO-HEALTH-MIB smHealthMonitorEntry 1.3.6.1.4.1.10876.2.1.1.1.1
SUPERMICRO-HEALTH-MIB smHealthMonitorIndex 1.3.6.1.4.1.10876.2.1.1.1.1.1
When I run the following, im getting an error:
./check_snmp -H 192.168.XX.XX -C public -o 1.3.6.1.4.1.10876.2.1
External command error: Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: iso.3.6.1.4.1.10876.2.1
What am I doing wrong?
Re: nagios snmp
You may want to walk the device first, if it works, then try focusing on specific oids::
Or for snmp v2c:
snmpwalk -v1 -c public 192.168.xx.xxCode: Select all
snmpwalk -v2c -c public 192.168.xx.xxFormer Nagios employee
nshahorchard
Re: nagios snmp
So, I've already done that and received a bunch of output:
Example -
HOST-RESOURCES-MIB::hrSWRunParameters.1824 = ""
HOST-RESOURCES-MIB::hrSWRunParameters.1860 = ""
HOST-RESOURCES-MIB::hrSWRunParameters.1900 = STRING: " "
HOST-RESOURCES-MIB::hrSWRunParameters.1992 = ""
HOST-RESOURCES-MIB::hrSWRunParameters.2100 = ""
HOST-RESOURCES-MIB::hrSWRunParameters.2236 = STRING: " "
HOST-RESOURCES-MIB::hrSWRunParameters.2416 = ""
HOST-RESOURCES-MIB::hrSWRunParameters.2428 = ""
HOST-RESOURCES-MIB::hrSWRunParameters.2700 = STRING: " "
HOST-RESOURCES-MIB::hrSWRunParameters.2712 = ""
HOST-RESOURCES-MIB::hrSWRunParameters.2772 =
Example -
nshahorchard
Re: nagios snmp
I guess my question would be, how do i find out the OIDs from the output of snmpwalk?
sreinhardt
- -fno-stack-protector
Re: nagios snmp
You need to provide it with the proper flags to do numeric output( -O n ). Otherwise the oid in mixed form is the far left string:
As for check_snmp, you need to tell it to use the specific mib or all mibs with (-m ALL).
nshahorchard
Re: nagios snmp
Here's a question. How do I find out the OIDs from a mib file?
And I been provided with:
SUPERMICRO-HEALTH-MIB SMHealthInfoTypes
SUPERMICRO-HEALTH-MIB smHealthMonitorName 1.3.6.1.4.1.10876.2.1.1.1.1.2
SUPERMICRO-HEALTH-MIB smHealthMonitorType 1.3.6.1.4.1.10876.2.1.1.1.1.3
SUPERMICRO-HEALTH-MIB smHealthMonitorReading 1.3.6.1.4.1.10876.2.1.1.1.1.4
SUPERMICRO-HEALTH-MIB smHealthMonitorHighLimit 1.3.6.1.4.1.10876.2.1.1.1.1.5
SUPERMICRO-HEALTH-MIB smHealthMonitorLowLimit 1.3.6.1.4.1.10876.2.1.1.1.1.6
SUPERMICRO-HEALTH-MIB smHealthMonitorMaxReading 1.3.6.1.4.1.10876.2.1.1.1.1.7
SUPERMICRO-HEALTH-MIB smHealthMonitorMinReading 1.3.6.1.4.1.10876.2.1.1.1.1.8
SUPERMICRO-HEALTH-MIB smHealthMonitorDivisor 1.3.6.1.4.1.10876.2.1.1.1.1.9
SUPERMICRO-HEALTH-MIB smHealthMonitorMonitor 1.3.6.1.4.1.10876.2.1.1.1.1.10
SUPERMICRO-HEALTH-MIB smHealthNotifications 1.3.6.1.4.1.10876.2.1.2
SUPERMICRO-HEALTH-MIB smHealthConformance 1.3.6.1.4.1.10876.2.1.3
SUPERMICRO-HEALTH-MIB smHealthCompliances 1.3.6.1.4.1.10876.2.1.3.1
SUPERMICRO-HEALTH-MIB smHealthCompliance 1.3.6.1.4.1.10876.2.1.3.1.1
SUPERMICRO-HEALTH-MIB smHealthGroups 1.3.6.1.4.1.10876.2.1.3.2
SUPERMICRO-HEALTH-MIB smHealthMonitorGroup 1.3.6.1.4.1.10876.2.1.3.2.1
-- SUPERMICRO-SMI.mib: Super Micro Enterprise Structure of Management Information
-- October 26 2001, Software LAB
-- Copyright (c) 1993-2001 by Super Micro Computer Inc.
-- All rights reserved.
SUPERMICRO-HEALTH-MIB DEFINITIONS ::= BEGIN
IMPORTS
MODULE-IDENTITY,
OBJECT-TYPE,
Integer32,
Gauge32
FROM SNMPv2-SMI
TEXTUAL-CONVENTION,
DisplayString,
TruthValue
FROM SNMPv2-TC
MODULE-COMPLIANCE,
OBJECT-GROUP
FROM SNMPv2-CONF
smHealth
FROM SUPERMICRO-SMI;
smHealthMIB MODULE-IDENTITY
LAST-UPDATED "200110260000Z"
ORGANIZATION "Super Micro Computer Inc."
CONTACT-INFO
" Software Lab
Postal: 980 Rock Avenue
San Jose, CA 95131
USA
Tel: +1 408 503 8000
E-mail: [email protected]"
DESCRIPTION
"MIB module for monitoring health information"
::= { smHealth 1 }
SMHealthInfoTypes ::= TEXTUAL-CONVENTION
STATUS current
DESCRIPTION
"Represents the different types of health information that
may be present in a managed device. The following health
information types are currently predefined:
0: fan speed
1: voltage
2: temperature
SYNTAX Integer32 (0..64)
smHealthObjects OBJECT IDENTIFIER ::= { smHealthMIB 1 }
smHealthMonitorTable OBJECT-TYPE
SYNTAX SEQUENCE OF SMHealthMonitorEntry
MAX-ACCESS not-accessible
STATUS current
DESCRIPTION
"A table of health monitoring entries."
::= { smHealthObjects 1 }
smHealthMonitorEntry OBJECT-TYPE
SYNTAX SMHealthMonitorEntry
STATUS current
DESCRIPTION
"An entry in the health monitoring table.
Entries cannot be created or deleted via SNMP operations."
INDEX { smHealthMonitorIndex }
::= { smHealthMonitorTable 1 }
SMHealthMonitorEntry ::=
SEQUENCE {
smHealthMonitorIndex Integer32,
smHealthMonitorName DisplayString,
smHealthMonitorType SMHealthInfoTypes,
smHealthMonitorReading Integer32,
smHealthMonitorHighLimit Integer32,
smHealthMonitorLowLimit Integer32,
smHealthMonitorMaxReading Integer32,
smHealthMonitorMinReading Integer32,
smHealthMonitorDivisor Integer32,
smHealthMonitorMonitor TruthValue
smHealthMonitorIndex OBJECT-TYPE
SYNTAX Integer32 (1..65535)
STATUS current
DESCRIPTION
"The unique value which identifies this Monitor device."
::= { smHealthMonitorEntry 1 }
smHealthMonitorName OBJECT-TYPE
SYNTAX DisplayString
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"A textual full name assigned to the Monitor device.
This object is suitable for output to a human operator."
::= { smHealthMonitorEntry 2 }
smHealthMonitorType OBJECT-TYPE
SYNTAX SMHealthInfoTypes
STATUS current
DESCRIPTION
STATUS current
DESCRIPTION
"Identifies this Monitor device type."
::= { smHealthMonitorEntry 3 }
smHealthMonitorReading OBJECT-TYPE
SYNTAX Integer32 (0..65535)
STATUS current
DESCRIPTION
"Indicates the value from the Monitor device that are
currently in use on the managed device.
FAN reading is in unit of RPM,
Voltage reading is in unit of mV,
Temperture reading is in unit of degree C"
::= { smHealthMonitorEntry 4 }
smHealthMonitorHighLimit OBJECT-TYPE
MAX-ACCESS read-write
STATUS current
DESCRIPTION
"Indicates the value for the High limitation
for the Monitor device that are currently in use on the
managed device.
Apply to Temperature and Voltage deivces only.
Voltage limit is in unit of mV,
Temperture limit is in unit of degree C"
::= { smHealthMonitorEntry 5 }
smHealthMonitorLowLimit OBJECT-TYPE
STATUS current
DESCRIPTION
"Indicates the value for the Low limitation
managed device.
FAN limit is in unit of RPM,
::= { smHealthMonitorEntry 6 }
nshahorchard
Re: nagios snmp
I see your point with the flags. How, in nagios, can i specify which mib file to use? I just threw them in /usr/share/snmp/mibs...I didn't know which variable allowed me to specify path of mib file. This is for 3rd party hardware (e.g Raid Conrtollers, Super Mico HArdware)
Re: nagios snmp
If you have not taken a look already, we have a few solutions for this which do have stand alone guides as far as I know:
http://nagios.sourceforge.net/docs/3_0/ ... ptrap.html
Also, I noted quite a few third party tutorials here:
https://www.google.com/search?q=how+to+ ... annel=fflb
nshahorchard
Re: nagios snmp
I've tried to implement some of those. Here is where my confusion is. When I find third party mib files. I am placing them inside of /usr/share/snmp/mibs. However, when i run snmpwalk, its not pulling any of the information for those mibs. What would cause this? I see its using the standard mib for the output. Aside from uploading the mib files in that directory, what else would I need to do to enable these outputs?
[root@nagios02 ~]# net-snmp-config --default-mibdirs
/root/.snmp/mibs:/usr/share/snmp/mibs
nshahorchard
Re: nagios snmp
making some headway here:
snmptranslate -m +SUPERMICRO-HEALTH-MIB -IR -On smHealthMonitorMinReading
.1.3.6.1.4.1.10876.2.1.1.1.1.8
What may be a dumb question...
How in the world can I get the true status instead of stating what the string is. In other words, What is the current voltage of the below?
[root@nagios02 ~]# ./check_snmp -H 192.168.XX.XX -C $COMM -o .1.3.6.1.4.1.10876.2.1.1.1.1.2.11
SNMP OK - CPU1 Vcore Voltage
snmpwalk -v 2c -c orchard 192.168.XX.XX SUPERMICRO -O n
.1.3.6.1.4.1.10876.2.1.1.1.1.2.1 = STRING: Fan1 Fan Speed
.1.3.6.1.4.1.10876.2.1.1.1.1.2.2 = STRING: Fan2 Fan Speed
.1.3.6.1.4.1.10876.2.1.1.1.1.2.3 = STRING: Fan3 Fan Speed
.1.3.6.1.4.1.10876.2.1.1.1.1.2.4 = STRING: Fan4 Fan Speed
.1.3.6.1.4.1.10876.2.1.1.1.1.2.5 = STRING: FanA Fan Speed
.1.3.6.1.4.1.10876.2.1.1.1.1.2.6 = STRING: FanB Fan Speed
.1.3.6.1.4.1.10876.2.1.1.1.1.2.7 = STRING: Power1 Fan 1 Speed
.1.3.6.1.4.1.10876.2.1.1.1.1.2.8 = STRING: Power1 Fan 2 Speed
.1.3.6.1.4.1.10876.2.1.1.1.1.2.9 = STRING: Power2 Fan 1 Speed
.1.3.6.1.4.1.10876.2.1.1.1.1.2.10 = STRING: Power2 Fan 2 Speed
.1.3.6.1.4.1.10876.2.1.1.1.1.2.11 = STRING: CPU1 Vcore Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.12 = STRING: CPU2 Vcore Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.13 = STRING: CPU1 VDIMM Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.14 = STRING: CPU2 VDIMM Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.15 = STRING: -12V Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.16 = STRING: +5VSB Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.17 = STRING: VTT Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.18 = STRING: +1.5V Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.19 = STRING: +5V Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.20 = STRING: +12V Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.21 = STRING: +3.3V Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.22 = STRING: +3.3VSB Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.23 = STRING: VBAT Voltage
.1.3.6.1.4.1.10876.2.1.1.1.1.2.24 = STRING: CPU1 Temperature
.1.3.6.1.4.1.10876.2.1.1.1.1.2.25 = STRING: CPU2 Temperature
.1.3.6.1.4.1.10876.2.1.1.1.1.2.26 = STRING: System Temperature
.1.3.6.1.4.1.10876.2.1.1.1.1.2.27 = STRING: Peripheral Temperature
.1.3.6.1.4.1.10876.2.1.1.1.1.2.28 = STRING: PCH Temperature
.1.3.6.1.4.1.10876.2.1.1.1.1.2.29 = STRING: Power1 Temperature
.1.3.6.1.4.1.10876.2.1.1.1.1.2.30 = STRING: Power2 Temperature
.1.3.6.1.4.1.10876.2.1.1.1.1.2.31 = STRING: Chassis Intrusion
.1.3.6.1.4.1.10876.2.1.1.1.1.2.32 = STRING: Power Supply Status
.1.3.6.1.4.1.10876.2.1.1.1.1.2.33 = STRING: Power1 Supply Failure
.1.3.6.1.4.1.10876.2.1.1.1.1.2.34 = STRING: Power2 Supply Failure
