Configuration verification failed
nottheadmin
Post by nottheadmin »
All of a sudden, When trying to add another host using the WMI monitoring wizard, The configuration wont take.
Configuration submitted for processing...
Waiting for configuration verification........
Configuration verification failed.
I have followed this guide - http://support.nagios.com/wiki/index.ph ... n_Problems.
Rand a config check
[root@localhost scripts]# ./reconfigure_nagios.sh &> reconfig.txt
[root@localhost scripts]# less reconfig.txt
Checking services...
        Checked 648 services.
Checking hosts...
        Checked 113 hosts.
Checking host groups...
        Checked 6 host groups.
Checking service groups...
        Checked 0 service groups.
Checking contacts...
Error: Contact 'Matt' has no service notification commands defined!
Error: Contact 'Matt' has no host notification commands defined!
        Checked 3 contacts.
Checking contact groups...
        Checked 2 contact groups.
Checking service escalations...
Checking service dependencies...
        Checked 0 service dependencies.
Checking host escalations...
        Checked 0 host escalations.
Checking host dependencies...
        Checked 0 host dependencies.
Checking commands...
        Checked 108 commands.
Checking time periods...
        Checked 8 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors:   2
***> One or more problems was encountered while running the pre-flight check...
     directives and data defintions.  If you are upgrading from a previous
     may have been removed or modified in this version.  Make sure to read
RET: 254
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors /usr/local/nagiosxi/scripts
tar: Removing leading `/' from member names
LATEST NOM SNAPSHOT: /usr/local/nagiosxi/nom/checkpoints/nagioscore/1392807423.tar.gz
/ /usr/local/nagiosxi/scripts
RESTORING NOM SNAPSHOT : /usr/local/nagiosxi/nom/checkpoints/nagioscore/1392807423.tar.gz
RESETTING PERMS
SETUID ROOT OK
reconfig.txt (END)
Appears to be a problem with the contact 'Matt'. That is me but I cannot recall where i input this information???
abrist
Red Shirt
Re: Configuration verification failed
Post by abrist »
Most users add templates to the contacts. Is this contact linked to an xi user? (named the same as an xi user)
If it is, you should configure the xi notification handlers for your contact or add the proper template.
For user configured contacts:
Use the template "xi_contact_generic" or:
Configure the notification commands on the contact.
Go to Configure --> CCM --> Contacts --> Click contact --> Click alert settings tab.
Click "Manage host notification commands" and add "xi_host_notification_handler" (this should be the only one added).
Click "Manage service notification commands" and add "xi_service_notification_handler" (this should be the only one added).
For contacts without user configuration:
Use the template "generic-contact" or:
Click "Manage host notification commands" and add "notify-host-by-emailr" (this should be the only one added).
Click "Manage service notification commands" and add "notify-service-by-email" (this should be the only one added).
nottheadmin
Yes that solved it, good to know that adding a contact but not configuring the templates will break it.
Thanks for your help!
Going to lock this up now. Feel free to open another thread if you have issues.
