HELP! I have lost graph data
benningtonr
I was recieving repeat text sat. and rebooted the nagios server. Since then i have no graph data.
HELP!!!
HELP!!!
Re: HELP! I have lost graph data
Lets start by tailing the perfdata logs:
tail -25 /usr/local/nagios/var/perfdata.log
tail -25 /usr/local/nagios/var/npcd.logFormer Nagios employee
benningtonr
[ronb@nagios libexec]$ tail -25 /usr/local/nagios/var/perfdata.log
2014-01-28 05:10:12 [13191] [0] *** TIMEOUT: Please check your npcd.cfg
2014-01-28 05:10:12 [13191] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1390903786.perfdata.service-PID-13191 deleted
2014-01-28 05:10:12 [13191] [0] *** Timeout while processing Host: "" Service: ""
2014-01-28 05:10:12 [13191] [0] *** process_perfdata.pl terminated on signal ALRM
2014-01-28 05:10:12 [13192] [0] *** TIMEOUT: Timeout after 5 secs. ***
2014-01-28 05:10:12 [13192] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2014-01-28 05:10:12 [13192] [0] *** TIMEOUT: Please check your npcd.cfg
2014-01-28 05:10:12 [13192] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1390903801.perfdata.host-PID-13192 deleted
2014-01-28 05:10:12 [13192] [0] *** Timeout while processing Host: "" Service: ""
2014-01-28 05:10:12 [13192] [0] *** process_perfdata.pl terminated on signal ALRM
2014-01-28 05:10:12 [13193] [0] *** TIMEOUT: Timeout after 5 secs. ***
2014-01-28 05:10:12 [13189] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1390903786.perfdata.host-PID-13189 deleted
2014-01-28 05:10:12 [13193] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2014-01-28 05:10:12 [13193] [0] *** TIMEOUT: Please check your npcd.cfg
2014-01-28 05:10:12 [13189] [0] *** Timeout while processing Host: "" Service: ""
2014-01-28 05:10:12 [13193] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1390903801.perfdata.service-PID-13193 deleted
2014-01-28 05:10:12 [13189] [0] *** process_perfdata.pl terminated on signal ALRM
2014-01-28 05:10:12 [13193] [0] *** Timeout while processing Host: "" Service: ""
2014-01-28 05:10:12 [13193] [0] *** process_perfdata.pl terminated on signal ALRM
2014-01-28 05:10:47 [13804] [0] *** TIMEOUT: Timeout after 5 secs. ***
2014-01-28 05:10:47 [13804] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2014-01-28 05:10:47 [13804] [0] *** TIMEOUT: Please check your npcd.cfg
2014-01-28 05:10:47 [13804] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//1390903831.perfdata.service-PID-13804 deleted
2014-01-28 05:10:47 [13804] [0] *** Timeout while processing Host: "cms1.whro.local" Service: "Memory_Usage"
2014-01-28 05:10:47 [13804] [0] *** process_perfdata.pl terminated on signal ALRM
[ronb@nagios libexec]$ tail -25 /usr/local/nagios/var/npcd.log
[12-23-2013 07:15:46] NPCD: ERROR: Executed command exits with return code '7'
[12-23-2013 07:15:46] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1387800927.perfdata.host'
[12-25-2013 04:20:50] NPCD: ERROR: Executed command exits with return code '7'
[12-25-2013 04:20:50] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1387963227.perfdata.service'
[01-15-2014 15:15:49] NPCD: ERROR: Executed command exits with return code '7'
[01-15-2014 15:15:49] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1389816925.perfdata.host'
[01-15-2014 15:15:49] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1389816925.perfdata.service'
[01-16-2014 15:40:51] NPCD: ERROR: Executed command exits with return code '7'
[01-16-2014 15:40:51] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1389904825.perfdata.service'
[01-20-2014 05:10:53] NPCD: ERROR: Executed command exits with return code '7'
[01-20-2014 05:10:53] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1390212625.perfdata.host'
[01-20-2014 05:10:53] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1390212625.perfdata.service'
[01-28-2014 05:10:12] NPCD: ERROR: Executed command exits with return code '7'
[01-28-2014 05:10:12] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1390903786.perfdata.service'
[01-28-2014 05:10:12] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1390903786.perfdata.host'
[01-28-2014 05:10:12] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1390903801.perfdata.service'
[01-28-2014 05:10:12] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1390903801.perfdata.host'
[01-28-2014 05:10:47] NPCD: ERROR: Executed command exits with return code '7'
[01-28-2014 05:10:47] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1390903831.perfdata.service'
[02-15-2014 17:17:24] NPCD: Caught Termination Signal - Hasta la vista... baby
You are experiencing timeouts. Increase the threshold by editing:benningtonr wrote:2014-01-28 05:10:12 [13192] [0] *** TIMEOUT: Timeout after 5 secs. ***
/usr/local/nagios/etc/pnp/process_perfdata.cfgCode: Select all
TIMEOUT = 5Code: Select all
TIMEOUT = 25Code: Select all
service npcd restartFormer Nagios employee
benningtonr
okay it has been changed, but i have had this up for a couple years, why would it all of a sudden need changed?
Have you added any checks as of late that may have increased the time necessary to receive and process checks? Or maybe some other tasks like backups, etc?
benningtonr
No checks, and no backup changes
benningtonr
yeah, graphs are back.
Did you do anything specific on your end to bring them back up?
