I upgraded Nagios XI yesterday. After the upgrade I noticed a localhost root partition warning.
The status information is Disk Warning - Free Space: /1771MB (19% inode=75%)
I successful resized the vdisk to 20GB by following the step in the Nagios XI – Resizing the VM Disk Size document.
The output is attached:
Tom Ransom
Localhost Root Partition Warning
hillhealthcenter
Thanks so much,
Tom
Tom
Re: Localhost Root Partition Warning
Can you force an immediate check for the disk check?
sreinhardt
- -fno-stack-protector
Are you still getting this warning? This is typical, as you noticed the inital vm disk size is rather small and quickly fills up with many hosts and services added in a live environment. What are your present host and service counts and do you have an estimated end amount for them both?
hillhealthcenter
Thanks for your reply.
The problem corrected itself.
Tom Ransom
Cornell Scott-Hill Health Center
Tom Ransom
Thanks so much,
Tom
Tom
Awesome! Probably just needed to wait for a fresh check to go through, or schedule it immediately. Thanks for letting us know.
