Quick help
cesar.garza
Quick help
Post by cesar.garza »
Hey guys
I have added the notes in my service.cfg so other teammate can get the help. In the note, I am just writing two endpoints but in the UI it shows everything on the same line. I tried to break the line but it didn't work. Please have a look the attachment. Any suggestions ??
sreinhardt
-fno-stack-protector
Re: Quick help
Post by sreinhardt »
Does this same effect happen when quoting your note with "" and using actual [enter] new lines instead of \n?
cesar.garza
Re: Quick help
sreinhardt wrote:Does this same effect happen when quoting your note with "" and using actual [enter] new lines instead of \n?
i tried with new line in the service.cfg but it shows everything in one line in the UI.
Re: Quick help
Post by slansing »
Yes, what sreinhardt was suggesting was using the enter key to actually create a new line, does this work?
cesar.garza
Re: Quick help
It didn't work like that either.
Re: Quick help
You should use the HTML tag "<br />" for a newline instead of "\n".
