External command error: Error in packet
romainalternatic
Post by romainalternatic »
Hello !
I installed Nagios on a computer in my society to control my network.
But, in a router's supervision, i have an error, and I don't know why.
This error is :
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: RFC1213-MIB::ifOperStatus.6
My code is :
	use		generic-switch		; Inherit default values from a template
	host_name	RouteurAlternatic	; The name we're giving to this switch
	alias		RouteurAlternatic	; A longer name associated with the switch
	address		192.168.51.254		; IP address of the switch
	hostgroups	switches		; Host groups this switch is associated with
	contact_groups 	admins
	use 		generic-switch
	host_name	RouteurSiege
	alias		RouteurSiege
	address		192.1.1.251
	hostgroups	switches
	use 		generic-switch
	host_name	FoneraAlternatic
	alias		FoneraAlternatic
	address		192.168.51.253
	hostgroups	switches
	use 		generic-switch
	alias		ns6757
	host_name	ns6757
	address
	hostgroups	switches
	use 		generic-switch
	alias 		RouteurBI
	host_name	RouteurBI
	address
	hostgroups 	switches
	use 		generic-switch
	alias		ns6642
	host_name	ns6642
	address
	hostgroups	switches
	use		generic-switch
	alias		ks365218
	host_name	ks365218
	address
	hostgroups	switches
	use 		generic-switch
	alias 		journaux.fr
	host_name	journaux.fr
	address
	hostgroups	switches
	use		generic-switch
	alias		discountpresse.com
	host_name	discountpresse.com
	address
	hostgroups	switches
	use		generic-switch
	alias		zepresse.fr
	host_name	zepresse.fr
	address
	hostgroups	switches
	use		generic-switch
	alias		lesfigurines.com
	host_name	lesfigurines.com
	address
	hostgroups	switches
	use		generic-switch
	alias		leportaildelabd.com
	host_name	leportaildelabd.com
	address
	hostgroups	switches
	use		generic-switch
	alias		ettwin.bourgogne-interim.com
	host_name	ettwin.bourgogne-interim.com
	address
	hostgroups	switches
	use		generic-switch
	alias		fm.alternatic.com
	host_name	fm.alternatic.com
	address
	hostgroups	switches
	use		generic-switch
	alias		glpiocs.alternatic.com
	host_name	glpiocs.alternatic.com
	address
	hostgroups	switches
# HOST GROUP DEFINITIONS
# Create a new hostgroup for switches
define hostgroup{
	hostgroup_name	switches		; The name of the hostgroup
	alias		Network Switches	; Long name of the group
# SERVICE DEFINITIONS
# Create a service to PING to switch
	use			generic-service	; Inherit values from a template
	host_name		RouteurAlternatic,RouteurSiege,FoneraAlternatic		; The name of the host the service is associated with
	service_description	PING							; The service description
	check_command		check_ping!600.0,20%!1000.0,90%				; The command used to monitor the service
	normal_check_interval	5							; Check the service every 5 minutes under normal conditions
	retry_check_interval	1
	contact_groups 	admins							; Re-check the service every minute until its final/hard state is determined
# Create a service to ping to servers
	use			generic-service
	host_name		ns6757,ns6642,ks365218,journaux.fr,discountpresse.com,zepresse.fr,lesfigurines.com,leportaildelabd.com,ettwin.bourgogne-interim.com,fm.alternatic.com,glpiocs.alternatic.com
	normal_check_interval	2
# Monitor uptime via SNMP
	host_name		RouteurAlternatic,RouteurSiege,RouteurBI,FoneraAlternatic,ns6757,ns6642,ks365218
	service_description	Uptime
	check_command		check_snmp!-C public -o sysUpTime.0
# Monitor Port 1 status via SNMP
	service_description	Port 1 Link Status
	check_command		check_snmp!-C public -o ifOperStatus.1 -r 1 -m RFC1213-MIB
#Port 2 status
	use			generic-service
	service_description	Port 2 Link Status
	check_command 		check_snmp!-C public -o ifOperStatus.2 -r 1 -m RFC1213-MIB
#Port 3 status
	use			generic-service
	service_description	Port 3 Link Status
	check_command 		check_snmp!-C public -o ifOperStatus.3 -r 1 -m RFC1213-MIB
#Port 4 status
	use			generic-service
	service_description	Port 4 Link Status
	check_command		check_snmp!-C public -o ifOperStatus.4 -r 1 -m RFC1213-MIB
#Port 5 status
	use 			generic-service
	service_description	Port 5 Link Status
	check_command		check_snmp!-C public -o ifOperStatus.5 -r 1 -m RFC1213-MIB
#Port 6 status
	use 			generic-service
	service_description	Port 6 Link Status
	check_command		check_snmp!-C public -o ifOperStatus.6 -r 1 -m RFC1213-MIB
#Port 7 status
	use 			generic-service
	service_description	Port 7 Link Status
	check_command		check_snmp!-C public -o ifOperStatus.7 -r 1 -m RFC1213-MIB
#Port 8 status
	use 			generic-service
	service_description	Port 8 Link Status
	check_command		check_snmp!-C public -o ifOperStatus.8 -r 1 -m RFC1213-MIB
#Surveillande du service HTTP
    use                	 	generic-service
    host_name         	 	journaux.fr,zepresse.fr,discountpresse.com,lesfigurines.com,leportaildelabd.com
    service_description 	HTTP
    check_command       	check_http
Can you help me please?
PS : sorry for my bad english ....
admin
Site Admin
Re: External command error: Error in packet
Post by admin »
What service or services are showing this error?
Ethan Galstad
President
romainalternatic
It is a router called RouteurAlternatic.
The configuration is :
And I have problem on ports no. 6, 7 and 8.
#Port 6 status
   use          generic-service
#Port 7 status
   use          generic-service
#Port 8 status
   use          generic-service
admin
Site Admin
Post by admin »
Are there 8 "regular" ports on the router? Perhaps port 6-8 are psuedo ports that don't support the ifOperstatus.X naming convention in the MIB.
Ethan Galstad
President
romainalternatic
yes i have 8 ports on my router. It is a Linksys RV082
