Hello Nagios Users,
Recently built nagios core 4.0.2 and nagios plugins 1.5 using the quickstart users guide. Everything turned out Ok with the exception I'm not able to acknowledge nagios alerts. Under "Service Commands" There are the following functions:
Disable Active Checks Of This Service Disable active checks of this service
Re-schedule Next Service Check Re-schedule the next check of this service
Submit Passive Check Result For This Service Submit passive check result for this service
Stop Accepting Passive Checks For This Service Stop accepting passive checks for this service
Stop Obsessing Over This Service Stop obsessing over this service
Disable Notifications For This Service Disable notifications for this service
Send Custom Notification Send custom service notification
Schedule Downtime For This Service Schedule downtime for this service
Disable Event Handler For This Service Disable event handler for this service
Disable Flap Detection For This Service Disable flap detection for this service
but there is no function to "Acknowledge This Service Problem". How can this be?
Is there something I missed during the build that is required to include this function? Or is there a setting in the nagios config files that needs to be declared? Any help is greatly appreciated.
Many thanks in advance,
michael.ucop
Service Command Acknowledgement Not Found
michael.ucop
michael.ucop
Re: Service Command Acknowledgement Not Found
Hello Nagios Users,
This is not an issue. I discovered that I selected a service that did not have a nagios alert and consequently no acknowledgement was available.
Nagios Core 4.0.2 is working fine.
