I've a little question. I've a service who chack on a cisco router the number of ip nat trans via snmp. Can I do a check on the value return? by example if number received is 125 I would like to have a chnge of sate.
Thanks in advance
Check on snmp value
tonyyarusso
Re: Check on snmp value
Sure - you just need to edit the plugin to add whatever logic you want.
