I have added the host through the CCM and I have configured alerts to be sent to my email I have not received any
Please advise
Thank you
Added Host and I not getting any alert
Re: Added Host and I not getting any alert
We will need a lot more details in order to help:
What version of XI are you using?
Have you clicked "Apply Config"?
Did you assign a user or a contact to the host?
Can you post the config for the host? Find it in the CCM and click the diskette icon to the right for "View Text Config" and paste the results here.
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/hosts/192.168.17.2.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/192.168.130.68.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/192.168.130.70.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/128.11.72.117.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/192.168.130.73.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/192.168.130.80.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/192.168.130.77.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/192.168.130.69.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/192.168.130.68.cfg'...
Processing object config file '/usr/local/nagios/etc/services/192.168.130.70.cfg'...
Processing object config file '/usr/local/nagios/etc/services/192.168.130.73.cfg'...
Processing object config file '/usr/local/nagios/etc/services/192.168.130.80.cfg'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/192.168.130.77.cfg'...
Processing object config file '/usr/local/nagios/etc/services/192.168.130.69.cfg'...
Error: Invalid max_attempts, check_interval, retry_interval, or notification_interval value for service 'BBCS-Queues-Stage' on host '192.168.130.68'
Error: Could not register service (config file '/usr/local/nagios/etc/services/192.168.130.70.cfg', starting on line 48)
License: GPL
Okay, so you are missing a number of config definitions that will cause you to not receive notifications. I would read through each definition that the verification showed you it failed on and make sure you assign the correct values from the CCM:
http://nagios.sourceforge.net/docs/3_0/ ... tions.html
thank you for the link it was helpful
