statusmap
tenda21
statusmap
Post by tenda21 »
how to put 2 computers connected to a router in statusmap instead of being attached directly to the center
Re: statusmap
You will need to make the router a parent of the hosts you want attached to it.
tenda21
Re: statusmap
Post by tenda21 »
I already have a router, but how to add the other computers to the router
Re: statusmap
You can just add the following line to the child hosts:
    parents    <router hostname>
to make the router their parent. Bear in mind this will not only place them behind the router on the map, but if the router goes down the hosts will be shown as unreachable.
tenda21
Re: statusmap
Post by tenda21 »
ok.
Tanks
Re: statusmap
Would you like us to keep this thread open while you test this out? Otherwise we will be closing it.
tenda21
Re: statusmap
Post by tenda21 »
may close
