Some of my servers are monitoring statistics on the server correctly and some are not.
This is one that is not correctly monitoring. See below
Host Service Status Last Check Duration Attempt Status Information
Marcel
C:\ Drive Space
WARNING 02-27-2014 09:44:49 0d 1h 48m 56s 3/3 could not fetch information from server
CPU Load
OK 02-27-2014 09:48:51 0d 0h 14m 54s 1/3 CPU Load 0% (5 min average)
E:\ Drive Space
WARNING 02-27-2014 09:48:53 0d 0h 4m 52s 3/3 could not fetch information from server
Memory Usage
WARNING 02-27-2014 09:50:54 0d 2h 22m 51s 3/3 could not fetch information from server
NSClient++ Version
WARNING 02-27-2014 09:50:56 0d 4h 16m 49s 3/3 could not fetch information from server
Uptime
WARNING 02-27-2014 09:46:58 0d 0h 40m 47s 3/3 could not fetch information from server
W3SVC
WARNING 02-27-2014 09:44:54 0d 0h 18m 51s 3/3 could not fetch information from server
How and Where can I troubleshoot this issue?
Statistics for drive space etc are screwed up for Servers
billperrotta
Re: Statistics for drive space etc are screwed up for Server
It looks like you are either using check_nt or check_nrpe to check this windows system correct? Could you post a service definition for one of your failing services? And the command it is using from commands.cfg? When running the command manually from the command line does it still return the 'Could not fetch' error?
billperrotta
See my commands.cfg below
# 'process-host-perfdata' command definition
command_name process-host-perfdata
command_line /usr/bin/printf "%b" "$LASTHOSTCHECK$\t$HOSTNAME$\t$HO STSTATE$\t$HOSTATTEMPT$\t$HOSTSTATETYPE$\t$HOSTEXECUTIONTIME$\t$HOSTOUTPUT$\t$ HOSTPERFDATA$\n" >> /var/lib/nagios/host-perfdata.out
(># 'process-service-perfdata' command definition
command_name process-service-perfdata
command_line /usr/bin/printf "%b" "$LASTSERVICECHECK$\t$HOSTNAME$\t $SERVICEDESC$\t$SERVICESTATE$\t$SERVICEATTEMPT$\t$SERVICESTATETYPE$\t$SERVICEE XECUTIONTIME$\t$SERVICELATENCY$\t$SERVICEOUTPUT$\t$SERVICEPERFDATA$\n" >> /var /lib/nagios/service-perfdata.out
251,0-1 Bot
Below this is marcel.cfg the machine with the monitoring issues
use windows-server
host_name Marcel
alias Marcel
address 10.1.8.10
hostgroups hotel-servers
parents AH-Marcel
host_name Marcel
service_description C:\ Drive Space
check_command check_nt!USEDDISKSPACE!-l C -w 80 -c 90
notification_interval 1440
notification_options w,r
notification_period work-holiday
servicegroups drivespace
5>}
host_name Marcel
"marcel.cfg" 30L, 699C 1,1 Top
251,0-1 Bot
use windows-server
host_name Marcel
alias Marcel
address 10.1.8.10
parents AH-Marcel
host_name Marcel
5>}
host_name Marcel
Are you running nsclient with or without a password?
You disk check fails, but no password is defined. The load check works, so could you post the config for that check?
billperrotta wrote:CPU Load
billperrotta
Sorry if I sound stupid. But I'm extremely new to this.
Which file contains that info so I can vi it and paste it here.
don't think it is using a password but i took over for another admin who is no longer here, so I wouldn't be able to tell you.
hopefully you can help me figure it out.
It would have been set up when you installed NSClient, it will be located on the remote system, in the nsc/nsclient.ini file, in nsclient's installation directory.
billperrotta
Here is the nsclient.ini below. this is on the server where the hard disks are coming up unknow.
Please use
# If you want to fill this file with all avalible options run the following command:
# nscp settings --generate --add-defaults --load-all
# nscp settings --activate-module <MODULE NAME> --add-defaults
; Undocumented section
[/modules]
; CheckDisk - CheckDisk can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckDisk = 1
; Event log Checker. - Check for errors and warnings in the event log. This is only supported through NRPE so if you plan to use only NSClient this wont help you at all.
CheckEventLog = 1
; Check External Scripts - A simple wrapper to run external scripts and batch files.
CheckExternalScripts = 1
; Helper function - Various helper function to extend other checks. This is also only supported through NRPE.
CheckHelpers = 1
; Check NSCP - Checkes the state of the agent
CheckNSCP = 1
; CheckSystem - Various system related checks, such as CPU load, process state, service state memory usage and PDH counters.
CheckSystem = 1
; CheckWMI - CheckWMI can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckWMI = 1
; NRPE server - A simple server that listens for incoming NRPE connection and handles them.
NRPEServer = 1
; NSCAClient - Passive check support over NSCA.
NSCAClient = 1
; NSClient server - A simple server that listens for incoming NSClient (check_nt) connection and handles them. Although NRPE is the preferred method NSClient is fully supported and can be used for simplicity or for compatibility.
NSClientServer = 1
[/settings/default]
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = 10.1.0.116
; A list of aliases available. An alias is an internal command that has been "wrapped" (to add arguments). Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop)
[/settings/external scripts/alias]
; alias_cpu - Alias for alias_cpu. To configure this item add a section called: /settings/external scripts/alias/alias_cpu
alias_cpu = checkCPU warn=80 crit=90 time=5m time=1m time=30s
; alias_cpu_ex - Alias for alias_cpu_ex. To configure this item add a section called: /settings/external scripts/alias/alias_cpu_ex
alias_cpu_ex = checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
; alias_disk - Alias for alias_disk. To configure this item add a section called: /settings/external scripts/alias/alias_disk
alias_disk = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED
; alias_disk_loose - Alias for alias_disk_loose. To configure this item add a section called: /settings/external scripts/alias/alias_disk_loose
alias_disk_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED ignore-unreadable
; alias_event_log - Alias for alias_event_log. To configure this item add a section called: /settings/external scripts/alias/alias_event_log
alias_event_log = CheckEventLog file=application file=system MaxWarn=1 MaxCrit=1 "filter=generated gt -2d AND severity NOT IN ('success', 'informational') AND source != 'SideBySide'" truncate=800 unique descriptions "syntax=%severity%: %source%: %message% (%count%)"
; alias_file_age - Alias for alias_file_age. To configure this item add a section called: /settings/external scripts/alias/alias_file_age
alias_file_age = checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1 "syntax=%filename% %write%"
; alias_file_size - Alias for alias_file_size. To configure this item add a section called: /settings/external scripts/alias/alias_file_size
alias_file_size = CheckFiles "filter=size > $ARG2$" "path=$ARG1$" MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%" max-dir-depth=10
; alias_mem - Alias for alias_mem. To configure this item add a section called: /settings/external scripts/alias/alias_mem
alias_mem = checkMem MaxWarn=80% MaxCrit=90% ShowAll=long type=physical type=virtual type=paged type=page
; alias_process - Alias for alias_process. To configure this item add a section called: /settings/external scripts/alias/alias_process
alias_process = checkProcState "$ARG1$=started"
; alias_process_count - Alias for alias_process_count. To configure this item add a section called: /settings/external scripts/alias/alias_process_count
alias_process_count = checkProcState MaxWarnCount=$ARG2$ MaxCritCount=$ARG3$ "$ARG1$=started"
; alias_process_hung - Alias for alias_process_hung. To configure this item add a section called: /settings/external scripts/alias/alias_process_hung
alias_process_hung = checkProcState MaxWarnCount=1 MaxCritCount=1 "$ARG1$=hung"
; alias_process_stopped - Alias for alias_process_stopped. To configure this item add a section called: /settings/external scripts/alias/alias_process_stopped
alias_process_stopped = checkProcState "$ARG1$=stopped"
; alias_sched_all - Alias for alias_sched_all. To configure this item add a section called: /settings/external scripts/alias/alias_sched_all
alias_sched_all = CheckTaskSched "filter=exit_code ne 0" "syntax=%title%: %exit_code%" warn=>0
; alias_sched_long - Alias for alias_sched_long. To configure this item add a section called: /settings/external scripts/alias/alias_sched_long
alias_sched_long = CheckTaskSched "filter=status = 'running' AND most_recent_run_time < -$ARG1$" "syntax=%title% (%most_recent_run_time%)" warn=>0
; alias_sched_task - Alias for alias_sched_task. To configure this item add a section called: /settings/external scripts/alias/alias_sched_task
alias_sched_task = CheckTaskSched "filter=title eq '$ARG1$' AND exit_code ne 0" "syntax=%title% (%most_recent_run_time%)" warn=>0
; alias_service - Alias for alias_service. To configure this item add a section called: /settings/external scripts/alias/alias_service
alias_service = checkServiceState CheckAll
; alias_service_ex - Alias for alias_service_ex. To configure this item add a section called: /settings/external scripts/alias/alias_service_ex
alias_service_ex = checkServiceState CheckAll "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
; alias_up - Alias for alias_up. To configure this item add a section called: /settings/external scripts/alias/alias_up
alias_up = checkUpTime MinWarn=1d MinWarn=1h
; alias_updates - Alias for alias_updates. To configure this item add a section called: /settings/external scripts/alias/alias_updates
alias_updates = check_updates -warning 0 -critical 0
; alias_volumes - Alias for alias_volumes. To configure this item add a section called: /settings/external scripts/alias/alias_volumes
alias_volumes = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED
; alias_volumes_loose - Alias for alias_volumes_loose. To configure this item add a section called: /settings/external scripts/alias/alias_volumes_loose
alias_volumes_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll=volumes FilterType=FIXED ignore-unreadable
; default - Alias for default. To configure this item add a section called: /settings/external scripts/alias/default
default =
allowed hosts = 127.0.0.1,10.1.0.0/24Code: Select all
[ /code] tags when posting large blocks of text, commands, or configs.[/color]-
sreinhardt
- -fno-stack-protector
Could you also post one of your nsclient.ini/nsc.ini that is working please? I don't see an alias for useddiskize in this config, however the nsclient man pages don't seem to indicate that it is needed, so I would just like to confirm against one of your working configs.
