CHECK_BY_SSH intermittant
I am having problems with the following message being received from check_by_ssh to remote Linux systems. (Return code of 255 is out of bounds)
This is an intermittent problem that occurs with a number of hosts but not all of them and only from time to time.
Running the full check from the command line manually works every time. The systems are not overly busy and respond well to other ssh requests.
check_by_ssh -H $HOSTADDRESS$ -l <username> -C "/nfs/imo/imofile2/user/tools/nagios/libexec/check_disk -w20% -c10% -p/var"
Username has the user on the remote system.
Re: CHECK_BY_SSH intermittant
Do you experience the issue when running the command from the cli? If so, could you increase the timeout and try to reproduce the issue again?
check_by_ssh -H $HOSTADDRESS$ -l <username> -t 60 -C "/nfs/imo/imofile2/user/tools/nagios/libexec/check_disk -w20% -c10% -p/var"Former Nagios employee
As noted previously, it works EVERY time.
You mean it works every time from the CLI, but works intermittently in the GUI correct? Can you post the service definition?
Yes, every time I run the service check from the command line using check_by _ssh it works. It is only when it is run automatically that it does not run. It will run often, but not all of the time. Changing the time out had no effect.
Here is the configuration.
# Service configuration file
# Created by: Nagios QL Version 3.0.3
# Date: 2014-02-27 13:16:50
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
service_description Unix - Check Var Directory
hostgroup_name Var Monitoring
display_name Unix - Check Var Directory
servicegroups Linux - Standard
check_command check_xi_by_ssh!<username>!"/nfs/imo/imofile2/user/tools/nagios/libexec/check_disk -w20% -c10% -p/var"!!!!!!
contact_groups Var System Monitoring
register 1
# END OF FILE
register 1
# END OF FILE
cunningrat
Redeming, I had a similar issue: checks would alert with the return code of "Plugin timed out while executing system call". Increasing the timeout value (the -t flag to check_by_ssh) fixed the problem.
@cunningrat - Thanks. I would have suggested the same thing...
The error I get does not seem to reflect a time out. Additionally, as mentioned in my last post, I tried increasing the timeout.
Is this happening with every plugin you are trying to execute via check_by_ssh?
