Nagios check_snmp error
wajidgates
Post by wajidgates »
I tried to add in a switch to monitor but i am getting below error.
CRITICAL - Plugin timed out while executing system call
i tried to run the command directly from CLI as below but same error came up:
./check_snmp -H 192.168.30.1 -C gpcc -o sysUpTimeInstance
Any suggestions ?
Regards
Abdul Wajid
Re: Nagios check_snmp error
Is this server really busy? I believe the default timeout on the check is 10 sec. Can you try running the command with "-t"=180 or higher?
./check_snmp -H 192.168.30.1 -t 180 -C gpcc -o sysUpTimeInstance
Is it timing out now?
