Scheduled report PDF errors
vAJ
Post by vAJ »
Running 2012r2.9
wkhtmltopdf 0.9.9
When a scheduled report fires with PDF output, the attachment is only a few hundred bytes and Acrobat throw the attached error.
httpd error log shows:
HTTP request sent, awaiting response... Unknown long argument --no-outline
is there a editable config where I can set HTMLtoPDF options for NagiosXI? Or is this in your compiled code?
Andrew J. - Do you even grok?
vAJ
Re: Scheduled report PDF errors
Post by vAJ »
CSV attachement looks good.
What type of report are you trying to schedule? Are you having issues with ALL scheduled reports? Can you download reports in the GUI as PDFs?
vAJ
Post by vAJ »
trying to DL a PDF report just gives me a white page.
Looks like the --no-outline option you are calling is not valid in 0.9.9, and current release is 0.12
OK to upgrade to latest?
I am not sure what went wrong but you should be using ver. 0.10.0 (that's what it is in our install script)...
Try reinstalling wkhtmltopdf:
cd /tmp/nagiosxi/subcomponents/wkhtml
./install
and check the version:
/usr/bin/wkhtmltopdf -V
vAJ
Post by vAJ »
Yep, looks like it didn't install at some point in the last few upgrades... Checked another instance that I don' t have any reports sending PDF and wkhtmltopdf wasn't even installed.
Anyhow, they're working now. Thx!
Post by slansing »
Awesome, we'll keep an eye out and see if this happens for other users, thank you!
