Not sure which email service was sending my nagios alerts?
billperrotta
Post by billperrotta »
What is the easiest way to figure out which email service was sending my Nagios alerts?
The email alerts have stopped working sinc the old admin left.
I do not think it is postfix because it doesn't respond to service postfix restart
Can somebody please tell me how to make nagios send a test email?
In Yast I have been able to determine it looks like postfix.
However I need to know how to make nagios send a test email.
Also how do i use chkconfig to start postfix at startup?
I need help testing this. Also how to define conditions to send the email.
I changed the old Admins email in contacts.cfg to the new admins. and no emails are being sent when servers go down.
sreinhardt
-fno-stack-protector
Re: Not sure which email service was sending my nagios alert
Post by sreinhardt »
Well, let's start with what notification commands your contacts are setup to use and how they are defined. Also are you using an internal or external mail server?
billperrotta
we have all internal mail servers. exchange unrelated. There is no nagios email there.
Postfix appears to be installed on my nagios server
see my contacts.cfg below
# CONTACTS.CFG - SAMPLE CONTACT/CONTACTGROUP DEFINITIONS
# Last Modified: 05-31-2007
# NOTES: This config file provides you with some example contact and contact
#        group definitions that you can reference in host and service
#        definitions.
#        You don't need to keep these definitions in a separate file from your
#        other object definitions.  This has been done just to make things
#        easier to understand.
# CONTACTS
# Just one contact defined by default - the Nagios admin (that's you)
# This contact definition inherits a lot of default values from the 'generic-contact'
# template which is defined elsewhere.
define contact{
        contact_name                    nagiosadmin		; Short name of user
	use				generic-contact		; Inherit default values from generic-contact template (defined above)
        alias                           Nagios Admin		; Full name of user
        email                           [email protected]	; <<***** CHANGE THIS TO YOUR EMAIL ADDRESS ******
define contact{
	contact_name 			nagiosuser
	use 				generic-contact
	alias 				Nagios User
	contactgroups 			admins
# CONTACT GROUPS
# We only have one contact in this simple configuration file, so there is
# no need to create more than one contact group.
define contactgroup{
        contactgroup_name       admins
        alias                   Nagios Administrators
        members                 nagiosadmin
Please use
 [/ code] tags for large blocks of text, commands, and configurations[/color][/size]
sreinhardt
Since your contacts do not have a notification command defined, could you show the generic-contact template? Please use
[code]
[/code] tags for submitting large text, commands, and configs.
Locking thread, as you have an identical one here: http://support.nagios.com/forum/viewtop ... 5840#90384
