Apply Configuration error
Sbergonzi
Post by Sbergonzi »
I've entered a new plugin (check_TomcatApplication) and running the command at the command prompt and testing via the Nagios UI works fine. I created a new host and service as well to test.
When I put in the command and "Apply Configuration" an error occurs and there doesn't seem to be any monitoring of the new service.
This is the error log, thoughts?
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/hosts/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Dev - User LDAP Store.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/10.192.156.116.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/Dev - Tomcat:ceteramfa.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/dev.auth.ceteraqa.com.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/DEV - PBD SW.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Dev-Tomcat:ceteramfa.cfg'...
Processing object config file '/usr/local/nagios/etc/services/Dev - User LDAP Store.cfg'...
Processing object config file '/usr/local/nagios/etc/services/10.192.156.116.cfg'...
Processing object config file '/usr/local/nagios/etc/services/dev.auth.ceteraqa.com.cfg'...
Processing object config file '/usr/local/nagios/etc/services/DEV - PBD SW.cfg'...
Error: Invalid max_check_attempts value for host 'Dev - Tomcat:ceteramfa'
Error: Could not register host (config file '/usr/local/nagios/etc/hosts/Dev - Tomcat:ceteramfa.cfg', starting on line 14)
Re: Apply Configuration error
It looks like you have an invalid max_check_attempts value for host 'Dev - Tomcat:ceteramfa'
Can you add in a valid max_check_attempts value for host 'Dev - Tomcat:ceteramfa'?
I would use a template like 'generic-host' for these things so nothing critical gets missed.
Sbergonzi
Post by Sbergonzi »
Let me start from the beginning... should I have done something different in between? I added max attempts and other errors are noted that I'm cleaning up.
1) uploaded the new plugin - ok
2) test the plugin at the command prompt - ok
3) create a new command - ok
4) Nagios UI notes to "Apply Configuration for new changes to take effect." - failed
Applying Configuration
Command submitted for processing...
Waiting for configuration verification.....
Configuration verification failed.
An error occurred while attempting to apply your configuration to Nagios Core. Monitoring engine configuration files have been rolled back to their last known good checkpoint.
5) created a service - ok
6) 'Test Check Command' - ok
7) Service --- 'Apply Configuration' - failed
Sbergonzi
Post by Sbergonzi »
Got it working. I had created a contact as well and had an error about 'No Service/Host commands'. I don't know what that meant so I removed it for now and that entry for the plugin is now showing.
I see that "Apply Configuration" isn't just for one screen, it's for the total amount of changes.
Correct - when you run Apply Config it handles all the changes you have made, and they do not take effect until you run Apply Config.
When you get an error like that, you will want to click the "View Latest Config Snapshot" button and the very top-most entry should be in red. Click the diskette icon and you will be able to review what went wrong so that you can correct it. Unfortunately Nagios only shows the first error, so it may take a few times to get it right. As I suggested before, you may want to look into using a template that handles all the defaults for you so you can avoid this in the future.
Sbergonzi
Post by Sbergonzi »
thank you!
Shall I lock up this thread now?
Sbergonzi
Post by Sbergonzi »
ok, thank you -
