HOSTSTATE doesnt always change correctly and I have read the support page but I need some more guidance.
I am trying to disable all notifications but have an event handler that shoots me a custom email after it has been down max_check_attempts which would equate to roughly 10 Minutes.
When I bring the IP offline it works correctly. When I bring it up after the max_check_attempts + some more time, the HOSTSTATEs are still correct. If I flap it real quick, the HOSTSTATE does not show correctly.
I basically want the logic to be if circuit is down and its been after max attempts, run custom code.
if( $HOSTSTATE =~ /DOWN/ && $SERVICEATTEMPT =~ /3/ )
# code ....
Thoughts?
Log of not working....
BRINGING IP OFFLINE
Fri Mar 7 10:55:10 2014
LASTHOSTCHECK: 1394207681
HOSTADDRESS: 216.187.15.113
HOSTSTATETYPE: SOFT
HOSTATTEMPT: 1
HOSTDISPLAYNAME: TESTSITE
HOSTSTATE: DOWN
MAXHOSTATTEMPTS: 3
SERVICESTATE: CRITICAL
SERVICESTATEID: 2
SERVICESTATETYPE: SOFT
SERVICEATTEMPT: 1
MAXSERVICEATTEMPTS: 3
BRINGING IP ONLINE
Fri Mar 7 10:56:11 2014
LASTHOSTCHECK: 1394207710
HOSTSTATETYPE: SOFT
HOSTATTEMPT: 2
HOSTSTATE: DOWN
MAXHOSTATTEMPTS: 3
SERVICESTATE: OK
SERVICESTATEID: 0
SERVICEATTEMPT: 2
I am guessing my logic for this should be to use SERVICESTATE instead.
if( $SERVICESTATE !~ /OK/ && $SERVICEATTEMPT =~ /3/ )
# code ....
BRINGING IP OFFLINE
Fri Mar 7 11:29:10 2014
LASTHOSTCHECK: 1394209714
HOSTSTATETYPE: SOFT
HOSTATTEMPT: 1
HOSTDISPLAYNAME: AlbertusMagnus
HOSTSTATE: DOWN
MAXHOSTATTEMPTS: 3
SERVICESTATEID: 2
SERVICEATTEMPT: 1
Fri Mar 7 11:30:10 2014
LASTHOSTCHECK: 1394209750
HOSTSTATETYPE: SOFT
HOSTATTEMPT: 2
HOSTSTATE: DOWN
MAXHOSTATTEMPTS: 3
SERVICESTATEID: 2
SERVICEATTEMPT: 2
BRINGING IP ONLINE
Fri Mar 7 11:31:11 2014
LASTHOSTCHECK: 1394209810
HOSTSTATETYPE: HARD
HOSTATTEMPT: 3
HOSTSTATE: DOWN
MAXHOSTATTEMPTS: 3
SERVICESTATE: OK
SERVICESTATEID: 0
SERVICEATTEMPT: 3
HOSTSTATE not changing ( my logic )
Re: HOSTSTATE not changing ( my logic )
Services on a host might be checked at different times or intervals than the actual host itself. You could have a host check interval of 20 minutes and a service interval of 1 minute. So you could very well see the service go up and down by plugging in and unplugging a network cable, and the host is never shown as down because it hasn't been re-checked in that time.
You will need to take this into consideration when determining your logic.
sreinhardt
- -fno-stack-protector
I think you would want hoststate and hostattempt for hosts and servicestate and serviceattempt for services, then since this is a global event handler, find a way to determine if this was a host check or service check.
