AIX Check for New Files
costanza2k1
Post by costanza2k1 »
Hi all,
I want to be able to see if there are any news files within a specific directory:
Directory:
/usr/IBM/WebSphere7.0/profiles/AppSrv01
Files:
If any new files show up in this directory named: *.txt, *.phd, *.trc
If there are any files with those extensions then I need a critical alert...any suggestions?
Re: AIX Check for New Files
Now there's an important distinction to make: Do you want to alert crit if there are *new* files or *any* files with those extensions?
I ask because the former will be a bit more complicated than the latter.
costanza2k1
tmcdonald wrote:Now there's an important distinction to make: Do you want to alert crit if there are *new* files or *any* files with those extensions?
The requirement is if there are any files with those extensions.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Here is a very basic check for what you are looking for. This will check the path given as the first argument for any comma separated list of extensions(without spaces). Such that a directory listing of
-rw------- 1 nagios users       303 Mar  7 13:30 checkjSpv6v
-rw------- 1 nagios nagios      257 Mar  4 14:58 checkpSs3D9
-rw-r--r-- 1 root   root          0 Feb 28 10:05 FLAG
drwxr-xr-x 6 root   nagcmd     4096 Nov  7 16:35 Getopt-Long-2.38
drwxr-xr-x 9 root   root       4096 Mar  4 15:02 nagiosxi
drwxr-xr-x 9 root   root       4096 Oct 21 17:53 vmware-vsphere-cli-distrib
-rw-r--r-- 1 root   root   38424689 Feb 11 14:11 xi-latest.tar.gz
Will return the following results:
./check_files.sh ./ check
Critical - Found files with bad extensions.
./check_files.sh ./ abcd
OK - No files with bad extensions found.
./check_files.sh ./ abcd,check
Plugin:
#!/bin/bash
# check if certain types of files exist.
IFS=","     # set separator for for loop
for ext in $2; do     # check for each file extension in given arg
        if [[ $(ls -lva $1 | grep -i $ext | wc -l) -gt 0 ]]; then     # if any files are found with this ext, will be greater than 0, exists on first find.
                echo Critical - Found files with bad extensions.
                exit 2
        fi
done
# if we get here, there have been no files found with those names.
echo OK - No files with bad extensions found.
exit 0
costanza2k1
Thank you! I'll try this now.
sreinhardt
You're welcome, let us know how it works for you. You are of course welcome to modify as needed, like if you would like to know how many of a given file type there were... However I don't want to get too deep into custom development.
