Trying to install the agent as per the instructions.
I get the following error:
launchctl start error: Bad file descriptor
Output of ls -l /Library/LaunchAgents/org.nagios.nrpe.plist is
-rw-r--r--@ 1 root admin 694 8 Mar 20:50 /Library/LaunchAgents/org.nagios.nrpe.plist
Any ideas??
Mac OS X agent install error
Re: Mac OS X agent install error
You are following this document correct?:
http://assets.nagios.com/downloads/nagi ... _Agent.pdf
Did you grab all three dependencies? Is there an installation log in the agent's untarred directory that you can share?
