R1.5
jlee
R1.5
Post by jlee »
We just upgraded from R1.2 to R1.5 and it lost all it time/date settings, and now it won't send out any email alerts. (but the test email does work).
any one else having the problems?
mguthrie
Re: R1.5
Post by mguthrie »
You can make sure your system time is accurate with the following commands:
yum install ntp
ntpdate pool.ntp.org
We'll keep our eyes peeled to see if anyone else is experiencing this.
jlee
Re: R1.5
Post by jlee »
I tried :
yum install ntp
but it didn't work.
I think our installed has died!
Reboot it and not it won't boot now :(
mguthrie
Re: R1.5
Post by mguthrie »
See if you can boot from a live cd and check the hard drive space. If it's completely full you would definitely have some problems.
jlee
Re: R1.5
Post by jlee »
I had to reinstall R1.5 because everything I tried didnt work.
However, on the new install the time is wrong again.
i.e. Wed Jul 6 11:30:54 CDT 2011
the time is the uk is 17:35.
I have tried
yum install ntp
but it didn't work.
How can I change time zone and getthe right time for the uk?
James
mguthrie
Re: R1.5
Post by mguthrie »
Can you elaborate on what you mean by "it didn't work." Are you able to install the yum package? Do you get an error when updating the time?
jlee
Re: R1.5
Post by jlee »
The steps worked.. but the time is still wrong. i.e I am in the UK.
if my time is :17:35 in the uk.
Nagios is saying 11:30:54 CDT 2011
How can I correct this? so nagios is showing the correct UK time?
James
mguthrie
Re: R1.5
Post by mguthrie »
What Linux distro is this on?
You may need to specify your timezone settings in your /etc/php.ini file.
You'll need to either edit or add:
 date.timezone = Etc/GMT-13
with your appropriate timezone.
http://nz.php.net/manual/en/timezones.php
When you run the "date" command from the command-line, do you get the correct date and time?
jlee
Re: R1.5
Post by jlee »
I have fixed the issue from running the following:
[root@linu-nag02 etc]# nano localtime
[root@linu-nag02 etc]# mv localtime localtime.old
[root@linu-nag02 etc]# ln -s /usr/share/zoneinfo/Europe/London /etc/localtime
James
jlee
Re: R1.5
Post by jlee »
Sorry another issue with the time.
Nagsoi now has the correct uk time.
However, when nagios sends out a email alert, the time on the email is incorrect.
How can I fix this?
James
