check_mrtgtraf: configuration broken
While I was trying to configure the check_mrtgtraf command in switch.cfg, somehow it won't let Nagios start now unless I have either the host_name or service_description commented out. I cannot have both uncommented and the service run. I am wondering what issues am I running into here.
sreinhardt
- -fno-stack-protector
Re: check_mrtgtraf: configuration broken
Have you tried verifying your configuration?
/path/to/nagios -v /path/to/nagios.cfgNagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
This is the error that comes up:
Error: Service check command 'check_mrtgtraf' specified in service 'Port 1 Bandwidth Usage' for host 'netgear-gsm7312' not defined anywhere!
Checked 12 services.Re: check_mrtgtraf: configuration broken
I think the answer might be in the error.
Have you in fact defined the check_mrtgtraf command anywhere?
It is not defined. After I posted, I found out that check_local_mrtgtraf is the proper definition. I replaced that and the nagios service started again. Unfortunately it is having issues getting the log which is why I messed with changing check_local_mrtgtraf to check_mrtgtraf.
What do you mean it is having trouble getting the log?
This is about all the information the logs are giving me:
MRTG is working, and I did point it to the correct log file which is sitting in /var/www/mrtg. I can view the traffic graph by going to http://10.0.0.42/mrtg/ where I see all the ports and then I can select, and check_mrtgtraf even works from the command-line with the parameters from switch.cfg, but from nagios it will not work.
[1394476809] SERVICE ALERT: netgear-gsm7312;Port 1 Bandwidth Usage;UNKNOWN;SOFT;1;check_mrtgtraf: Unable to open MRTG log file
[1394476929] SERVICE ALERT: netgear-gsm7312;Port 1 Bandwidth Usage;UNKNOWN;SOFT;2;check_mrtgtraf: Unable to open MRTG log file
[1394477049] SERVICE ALERT: netgear-gsm7312;Port 1 Bandwidth Usage;UNKNOWN;HARD;3;check_mrtgtraf: Unable to open MRTG log fileRe: check_mrtgtraf: configuration broken
Do you get any errors, when you run the following command?
What mrtg packages do you have installed? If it is a CentOS system, you can run:
Did you check the permissions?
Can you show us the mrtg cron entry?
Note: Adjust the paths if you need to.
LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfgCode: Select all
yum list installed mrtg*Code: Select all
ls -lad /etc/mrtg/
ls -la /etc/mrtg/
ls -la /var/lib/mrtg/
ls -la /usr/local/nagios/libexec/check_mrtgtrafCode: Select all
cat /etc/cron.d/mrtgBe sure to check out our Knowledgebase for helpful articles and solutions!
Runs fine.lmiltchev wrote:Do you get any errors, when you run the following command?
mrtg.x86_64 2.16.2-7.el6 @base
mrtg-libs.x86_64 2.16.2-7.el6 @baseDid you check the permissions?
ls -lad /etc/mrtg/ ls -la /etc/mrtg/ ls -la /var/lib/mrtg/ ls -la /usr/local/nagios/libexec/check_mrtgtraf
drwxr-xr-x. 2 root root 4096 Mar 12 13:09 /etc/mrtg
total 28
drwxr-xr-x. 2 root root 4096 Mar 12 13:09 .
drwxr-xr-x. 83 root root 4096 Mar 5 15:15 ..
-rw-r--r--. 1 root root 17916 Mar 5 15:59 mrtg.cfg
-rw-r--r--. 1 root root 0 Mar 12 13:09 mrtg.ok
total 8
drwxrwxrwx. 2 nagios nagios 4096 Feb 27 16:55 .
drwxr-xr-x. 28 root root 4096 Mar 5 14:16 ..
-rw-r--r--. 1 root root 0 Mar 12 13:10 mrtg.ok
-rwxr-xr-x. 1 root root 40240 Oct 17 06:43 /usr/lib64/nagios/plugins/check_mrtgtraf
Can you show us the mrtg cron entry?Note: Adjust the paths if you need to.Code: Select all
*/5 * * * * root LANG=C LC_ALL=C /usr/bin/mrtg /etc/mrtg/mrtg.cfg --lock-file /var/lock/mrtg/mrtg_l --confcache-file /var/lib/mrtg/mrtg.ok-
sreinhardt
Well I can see why the nagios check is failing, we don't have any rrd files for it to read in /var/lib/mrtg. Could you post your /etc/mrtg.cfg please, and we can look it over for issues.
