Mar 10 20:20:42 nagios nsca[4877]: SERVICE CHECK -> Host Name: 'PN-ACIESIELSKI1', Service Description: 'MEM Load', Return Code: '0', Output: 'OK: physical memory: Total: 2.97G - Used: 880M (28%) - Free: 2.11G (72%)|'physical memory %'=28%;80;90 'physical memory'=879.5M;2429.69;2733.4;0;3037.11'
Mar 10 20:20:42 nagios nagios: EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;PN-ACIESIELSKI1;MEM Load;0;OK: physical memory: Total: 2.97G - Used: 880M (28%) - Free: 2.11G (72%)|'physical memory %'=28%;80;90 'physical memory'=879.5M;2429.69;2733.4;0;3037.11
Mar 10 20:20:42 nagios nagios: PASSIVE SERVICE CHECK: PN-ACIESIELSKI1;MEM Load;0;OK: physical memory: Total: 2.97G - Used: 880M (28%) - Free: 2.11G (72%)
Mar 10 20:20:42 nagios nagios: SERVICE ALERT: PN-ACIESIELSKI1;MEM Load;OK;HARD;3;OK: physical memory: Total: 2.97G - Used: 880M (28%) - Free: 2.11G (72%)
Mar 10 20:21:53 nagios nagios: SERVICE ALERT: PN-ACIESIELSKI1;DISK Load C;CRITICAL;HARD;3;(No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_nrpe, ...) failed. errno is 2: No such file or directory
Mar 10 20:21:53 nagios nagios: SERVICE NOTIFICATION: nagiosadmin;PN-ACIESIELSKI1;DISK Load C;CRITICAL;notify-service-by-email;(No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_nrpe, ...) failed. errno is 2: No such file or directory
Mar 10 20:22:55 nagios nsca[5076]: SERVICE CHECK -> Host Name: 'PN-ACIESIELSKI1', Service Description: 'DISK Load C', Return Code: '0', Output: 'OK: All drives within bounds.|'C: %'=61%;10;5 'C:'=38.62G;9.75999;4.87999;0;97.65'
Mar 10 20:22:55 nagios nagios: EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;PN-ACIESIELSKI1;DISK Load C;0;OK: All drives within bounds.|'C: %'=61%;10;5 'C:'=38.62G;9.75999;4.87999;0;97.65
Mar 10 20:22:55 nagios nagios: PASSIVE SERVICE CHECK: PN-ACIESIELSKI1;DISK Load C;0;OK: All drives within bounds.
Mar 10 20:22:55 nagios nagios: SERVICE ALERT: PN-ACIESIELSKI1;DISK Load C;OK;HARD;3;OK: All drives within bounds.
Mar 10 20:25:49 nagios nsca[5386]: SERVICE CHECK -> Host Name: 'PN-ACIESIELSKI1', Service Description: 'CPU Load', Return Code: '0', Output: 'OK CPU Load ok.|'5m'=4%;80;90 '1m'=3%;80;90 '30s'=4%;80;90'
Mar 10 20:25:49 nagios nagios: EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;PN-ACIESIELSKI1;CPU Load;0;OK CPU Load ok.|'5m'=4%;80;90 '1m'=3%;80;90 '30s'=4%;80;90
Mar 10 20:25:49 nagios nagios: PASSIVE SERVICE CHECK: PN-ACIESIELSKI1;CPU Load;0;OK CPU Load ok.
Mar 10 20:25:49 nagios nagios: SERVICE ALERT: PN-ACIESIELSKI1;CPU Load;OK;HARD;3;OK CPU Load ok.
Mar 10 20:30:05 nagios nagios: SERVICE ALERT: PN-ACIESIELSKI1;MEM Load;CRITICAL;SOFT;1;(No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_nrpe, ...) failed. errno is 2: No such file or directory
Mar 10 20:30:36 nagios nagios: SERVICE ALERT: PN-ACIESIELSKI1;CPU Load;CRITICAL;SOFT;1;(No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_nrpe, ...) failed. errno is 2: No such file or directory
Mar 10 20:30:41 nagios nsca[5904]: SERVICE CHECK -> Host Name: 'PN-ACIESIELSKI1', Service Description: 'MEM Load', Return Code: '0', Output: 'OK: physical memory: Total: 2.97G - Used: 879M (28%) - Free: 2.11G (72%)|'physical memory %'=28%;80;90 'physical memory'=879.06M;2429.69;2733.4;0;3037.11'
Mar 10 20:30:41 nagios nagios: EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;PN-ACIESIELSKI1;MEM Load;0;OK: physical memory: Total: 2.97G - Used: 879M (28%) - Free: 2.11G (72%)|'physical memory %'=28%;80;90 'physical memory'=879.06M;2429.69;2733.4;0;3037.11
Mar 10 20:30:41 nagios nagios: PASSIVE SERVICE CHECK: PN-ACIESIELSKI1;MEM Load;0;OK: physical memory: Total: 2.97G - Used: 879M (28%) - Free: 2.11G (72%)
Mar 10 20:30:41 nagios nagios: SERVICE ALERT: PN-ACIESIELSKI1;MEM Load;OK;SOFT;2;OK: physical memory: Total: 2.97G - Used: 879M (28%) - Free: 2.11G (72%)
Mar 10 20:31:53 nagios nagios: SERVICE ALERT: PN-ACIESIELSKI1;DISK Load C;CRITICAL;SOFT;1;(No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_nrpe, ...) failed. errno is 2: No such file or directory
Mar 10 20:32:05 nagios nagios: SERVICE ALERT: PN-ACIESIELSKI1;MEM Load;CRITICAL;SOFT;1;(No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_nrpe, ...) failed. errno is 2: No such file or directory
Mar 10 20:32:36 nagios nagios: SERVICE ALERT: PN-ACIESIELSKI1;CPU Load;CRITICAL;SOFT;2;(No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_nrpe, ...) failed. errno is 2: No such file or directory
Mar 10 20:32:55 nagios nsca[6114]: SERVICE CHECK -> Host Name: 'PN-ACIESIELSKI1', Service Description: 'DISK Load C', Return Code: '0', Output: 'OK: All drives within bounds.|'C: %'=61%;10;5 'C:'=38.62G;9.75999;4.87999;0;97.65'
Mar 10 20:32:55 nagios nagios: EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;PN-ACIESIELSKI1;DISK Load C;0;OK: All drives within bounds.|'C: %'=61%;10;5 'C:'=38.62G;9.75999;4.87999;0;97.65
Mar 10 20:32:55 nagios nagios: PASSIVE SERVICE CHECK: PN-ACIESIELSKI1;DISK Load C;0;OK: All drives within bounds.
Mar 10 20:32:55 nagios nagios: SERVICE ALERT: PN-ACIESIELSKI1;DISK Load C;OK;SOFT;2;OK: All drives within bounds.
What else information do you need to help me?
