Nagios Core Startup Issue
So I am trying to migrate our nagios core system from a freeBSD box to a CentOS system.
it is a version upgrade from 3.5.0 to 3.5.1.
I installed the CentOS nagios version using EPEL respository.
As a default install it worked showing the local host.
I then copy over and config files and check scripts. Updated anything that appeared to have a bad path/invalid path.
The nagios -v (config file path) check is passing but the service will not start.
___________________________________
Checking services...
Checked 3391 services.
Checking hosts...
Checked 753 hosts.
Checking host groups...
Checked 391 host groups.
Checking service groups...
Checked 23 service groups.
Checking contacts...
Checked 8 contacts.
Checking contact groups...
Checked 6 contact groups.
Checking service escalations...
Checked 10173 service escalations.
Checking service dependencies...
Checked 1655 service dependencies.
Checking host escalations...
Checked 2259 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 53 commands.
Checking time periods...
Checked 4 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors: 0
[hostname]# service nagios start
Starting nagios:CONFIG ERROR! Start aborted. Check your Nagios configuration.
_____________________________________________________________
No nagios or system logs are being generated so i cant find the issue. I think it has something to do with my config file because, if i remove them and replace with samples the service starts and runs.
Any help would be great thanks.
Checking hosts...
Checked 753 hosts.
Checked 8 contacts.
Total Warnings: 0
Total Errors: 0
Re: Nagios Core Startup Issue
Usually that means there's an error in one of your nagios config files. I'll look directly at nagios.cfg personally...
Also you can run a strace on the binary and see if that might tell you more of whats going on.
Nagios Jedi in training.
Ok, running right off the binary pointing to the config file its starting. all thought not pulling services only host ICMP. (maybe broker config?)
Not sure why the init file is not working correctly.
Whats the best way to get the init file working again, or find out why its not working?
sreinhardt
- -fno-stack-protector
You probably want to, as you thought, look at the init file in /etc/init.d/nagios. You could also post it here for us to look at. Specifically I would say you need to look at what prefix and NagiosCfgFile are equal to, and make sure they are pointing at the right places.
I have it running now with out the init script.
Looking at the paths they all seem correct. Not sure why this keeps failing.
#!/bin/sh
# chkconfig: - 99 01
# description: Nagios network monitor
# File : nagios
# Author : Jorge Sanchez Aymar ([email protected])
# Changelog :
# 1999-07-09 Karl DeBisschop <[email protected]>
# - setup for autoconf
# - add reload function
# 1999-08-06 Ethan Galstad <[email protected]>
# - Added configuration info for use with RedHat's chkconfig tool
# per Fran Boon's suggestion
# 1999-08-13 Jim Popovitch <[email protected]>
# - added variable for nagios/var directory
# - cd into nagios/var directory before creating tmp files on startup
# 1999-08-16 Ethan Galstad <[email protected]>
# - Added test for rc.d directory as suggested by Karl DeBisschop
# 2000-07-23 Karl DeBisschop <[email protected]>
# - Clean out redhat macros and other dependencies
# 2003-01-11 Ethan Galstad <[email protected]>
# - Updated su syntax (Gary Miller)
# Description: Starts and stops the Nagios monitor
# used to provide network services status.
# Load any extra environment variables for Nagios and its plugins
if test -f /etc/sysconfig/nagios; then
. /etc/sysconfig/nagios
fi
status_nagios ()
if test -x $NagiosCGI/daemonchk.cgi; then
if $NagiosCGI/daemonchk.cgi -l $NagiosRunFile; then
return 0
else
return 1
fi
else
if ps -p $NagiosPID > /dev/null 2>&1; then
return 0
else
return 1
fi
fi
return 1
printstatus_nagios()
status_nagios $1 $2
RETVAL=$?
if [ $RETVAL = 0 ]; then
echo "nagios (pid $NagiosPID) is running..."
else
echo "nagios is not running"
fi
return $RETVAL
killproc_nagios ()
kill $2 $NagiosPID
pid_nagios ()
if test ! -f $NagiosRunFile; then
echo "No lock file found in $NagiosRunFile"
exit 1
fi
NagiosPID=`head -n 1 $NagiosRunFile`
# Source function library
# Solaris doesn't have an rc.d directory, so do a test first
if [ -f /etc/rc.d/init.d/functions ]; then
. /etc/rc.d/init.d/functions
elif [ -f /etc/init.d/functions ]; then
. /etc/init.d/functions
fi
prefix=/usr/share/nagios
exec_prefix=/var/lib/nagios
NagiosBin=/usr/sbin/nagios
NagiosCfgFile=/etc/nagios/nagios.cfg
NagiosStatusFile=/var/log/nagios/status.dat
NagiosRetentionFile=/var/log/nagios/retention.dat
NagiosCommandFile=/var/log/nagios/rw/nagios.cmd
NagiosVarDir=/var/log/nagios
NagiosRunFile=/var/run/nagios.pid
NagiosLockDir=/var/lock/subsys
NagiosLockFile=nagios
NagiosCGIDir=/usr/sbin
NagiosUser=nagios
NagiosGroup=nagios
# Check that nagios exists.
if [ ! -f $NagiosBin ]; then
echo "Executable file $NagiosBin not found. Exiting."
exit 1
fi
# Check that nagios.cfg exists.
if [ ! -f $NagiosCfgFile ]; then
echo "Configuration file $NagiosCfgFile not found. Exiting."
exit 1
fi
# See how we were called.
case "$1" in
start)
echo -n "Starting nagios:"
$NagiosBin -v $NagiosCfgFile > /dev/null 2>&1;
if [ $? -eq 0 ]; then
touch $NagiosVarDir/nagios.log $NagiosRetentionFile
chown $NagiosUser:$NagiosGroup $NagiosVarDir/nagios.log $NagiosRetentionFile
rm -f $NagiosCommandFile
touch $NagiosRunFile
chown $NagiosUser:$NagiosGroup $NagiosRunFile
[ -x /sbin/restorecon ] && /sbin/restorecon $NagiosRunFile
$NagiosBin -d $NagiosCfgFile
if [ -d $NagiosLockDir ]; then touch $NagiosLockDir/$NagiosLockFile; fi
echo " done."
exit 0
else
echo "CONFIG ERROR! Start aborted. Check your Nagios configuration."
exit 1
fi
stop)
echo -n "Stopping nagios: "
pid_nagios
killproc_nagios nagios
# now we have to wait for nagios to exit and remove its
# own NagiosRunFile, otherwise a following "start" could
# happen, and then the exiting nagios will remove the
# new NagiosRunFile, allowing multiple nagios daemons
# to (sooner or later) run - John Sellens
#echo -n 'Waiting for nagios to exit .'
for i in 1 2 3 4 5 6 7 8 9 10 ; do
if status_nagios > /dev/null; then
echo -n '.'
sleep 1
else
break
fi
done
echo ''
echo 'Warning - nagios did not exit in a timely manner'
else
echo 'done.'
fi
rm -f $NagiosStatusFile $NagiosRunFile $NagiosLockDir/$NagiosLockFile $NagiosCommandFile
status)
pid_nagios
printstatus_nagios nagios
exit $?
checkconfig)
printf "Running configuration check..."
echo " OK."
else
echo " CONFIG ERROR! Check your Nagios configuration."
exit 1
fi
restart)
echo "done."
$0 stop
$0 start
else
echo " CONFIG ERROR! Restart aborted. Check your Nagios configuration."
exit 1
fi
reload|force-reload)
echo "done."
$0 start
else
pid_nagios
printf "Reloading nagios configuration..."
killproc_nagios nagios -HUP
echo "done"
else
$0 stop
$0 start
fi
fi
else
echo " CONFIG ERROR! Reload aborted. Check your Nagios configuration."
exit 1
fi
echo "Usage: nagios {start|stop|restart|reload|force-reload|status|checkconfig}"
exit 2
esac
# End of this script-
sreinhardt
Looks like you are probably having an issue here:
Could you run a verification and then run echo $? like so:
if [ $? -eq 0 ]; thenCode: Select all
/usr/sbin/nagios -v /etc/nagios/nagios.cfg
echo $?Nagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
Thats where I thought it was dying as I get the echo of :
But after running nagios -v (config path)
echo $? returns 0
So I wonder where its going bad.
echo $? returns 0
adding the following from init.
nagiosbin appears correct and every one should be able to execute
-rwxr-xr-x. 1 root root 652384 Aug 30 2013 nagios
config file is at /etc/nagios/nagios.cfg
Its even passing in the first two checks on start where it looks for that. Yet the returned string is
suggesting that $? -eq 0 is something other then 0
sreinhardt
Well, let's verify exactly what we are getting then. Try altering the init script to have this portion instead for start():
$NagiosBin -v $NagiosCfgFile ; # removed redirection
echo "Passed test - exit $?" # Added this
echo " done."
exit 0
else
echo "Failed test - exit $?" # Added this
exit 1
fi
;;Nagios-Plugins maintainer exclusively, unless you have other C language bugs with open-source nagios projects, then I am happy to help! Please pm or use other communication to alert me to issues as I no longer track the forum.
OK, getting some where.
Error: Cannot open resource file '/etc/nagios/private/resource.cfg' for reading!
Read main config file okay...
Processing object config directory '/etc/nagios/objects'...
Error: Could not open config directory '/etc/nagios/objects' for reading.
Failed test - exit 1
Files and folders below to nagios and the nagios group/apache member of group. owner has rw over all and group has r some files are default r also
What should these be? do they all need X?
