Disable Flap
cesar.garza
Disable Flap
Post by cesar.garza »
Hey Guys
I want to disable flap for whole nagios and found the config in template.cfg. I changed from 1 to 0 but just wondering that Nagios UI should show (Flap Detection = Red) in Service/Host state Information page but its showing Green to me.
Re: Disable Flap
Post by slansing »
I believe you would want to change this in the nagios.cfg:
enable_flap_detection=0
Then it should work properly, if you just change a template, it will only effect objects to which that template is assigned, and that are inheriting it's definition for flap detection.
cesar.garza
Re: Disable Flap
Yes, I just noticed that there are two separate places for Host and Service to disable Flap.
Thanks for help
