Timeout without warning?
idefixgallier
Post by idefixgallier »
Hi!
[12-03-2014 09:50:07] wproc: Core Worker 4124: job 95209 (pid=18245): Dormant child reaped
Informational Message[12-03-2014 09:50:02] wproc: Core Worker 4124: Failed to reap child with pid 18245. Next attempt @ 1394614207.572255
Informational Message[12-03-2014 09:50:02] wproc: Core Worker 4124: tv.tv_sec is currently 1394614202
Informational Message[12-03-2014 09:50:02] Warning: Check of service 'Scalix-Webmail' on host 'sxalumni.fhstp.ac.at' timed out after 90.004s!
Informational Message[12-03-2014 09:50:02] wproc: early_timeout=1; exited_ok=0; wait_status=0; error_code=62;
Informational Message[12-03-2014 09:50:02] wproc: host=sxalumni.fhstp.ac.at; service=Scalix-Webmail;
Informational Message[12-03-2014 09:50:02] wproc: command: /opt/nagios/libexec/check_http -H sxalumni.fhstp.ac.at -u /webmail/ -I 195.202.144.4 -t 99
Informational Message[12-03-2014 09:50:02] wproc: CHECK job 95209 from worker Core Worker 4124 timed out after 90.00s
Informational Message[12-03-2014 09:50:02] wproc: Core Worker 4124: job 95209 (pid=18245) timed out. Killing it
This timeout was never reported (and of course no event handler was started) - can somebody give me a hint where to search why?
Martin
sreinhardt
-fno-stack-protector
Re: Timeout without warning?
Post by sreinhardt »
Please run the following command and output the results.
grep -i 'timeout' /usr/local/nagios/etc/nagios.cfg
idefixgallier
here you go :)
root@nagios:/opt/nagios/etc# grep -i timeout nagios.cfg
# TIMEOUT VALUES
service_check_timeout=90
host_check_timeout=30
event_handler_timeout=240
notification_timeout=120
ocsp_timeout=5
perfdata_timeout=5
lg
Martin
sreinhardt
I'm not sure if this is an expected thing with core or not. However the worker killed your check before it could return any output or status for it timing out as the max service timeout within core is set to 90 seconds and your plugin had a timeout of 99 seconds. Increasing the max timeout within core or decreasing it on the plugin below 90 should resolve this issue. I will check on what behavior is expected when core kills a check, as I would expect at least an unknown if not critical.
idefixgallier
As I have written the grep -i timeout output it has become
reasonable for me
service_check_timeout=90 and a ... -t 99 could not work together very well...
(and now the "but" :) )
but
until 4.0.3 this raised no problems. I will lower the -t value, it is more logical
in the way 4.0.3 handles that.
Thank you!
Let us know if we can mark this topic as "resolved".
idefixgallier
I think you can - thank you for your help!!!
