Installing Nagios without rpmforge
hondain
Post by hondain »
Hi All
Is there a way to install Nagios without using RPMforge.
This system is receiving updates from Red Hat Subscription Management.
Enabling RPMForge repo...
Installing RPMForge PKG: packages/rpmforge-release-0.5.2-2.el6.rf.ppc64.rpm
error: open of packages/rpmforge-release-0.5.2-2.el6.rf.ppc64.rpm failed: No such file or directory
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './0-yum'
Nagios XI 5.3.2
CENT-OS as vm host
Text mode with proxy
abrist
Red Shirt
Re: Installing Nagios without rpmforge
Post by abrist »
You could try commenting out the rpmforge line from the installer and see if you can get the rest of xi installed.
hondain
Post by hondain »
Can you please provide me the list of rpm needed if we comment rpmforge
Nagios XI 5.3.2
CENT-OS as vm host
abrist
Red Shirt
Post by abrist »
[root@nagiosxi ~]# yum list installed | grep rf
fping.x86_64                          3.4-1.el6.rf                     @rpmforge
htop.x86_64                           1.0.2-1.el6.rf                   @rpmforge
perl-Email-Simple.noarch              2.100-2.el6.rf                   @rpmforge
perl-Nagios-Plugin.noarch             0.35-2.el6.rf                    @rpmforge
perl-Net-SMTP-TLS.noarch              0.12-1.el6.rf                    @rpmforge
perl-Net-SNMP-HostInfo.noarch         0.04-1.2.el6.rf                  @rpmforge
perl-SNMP-Multi.noarch                2.1-1.el6.rf                     @rpmforge
perl-SNMP-NPAdmin.noarch              1.0-1.el6.rf                     @rpmforge
perl-XML-NamespaceFactory.noarch      1.00-1.el6.rf                    @rpmforge
php-mcrypt.x86_64                     5.3.3-1.el6.rf                   @rpmforge
rpmforge-release.x86_64               0.5.3-1.el6.rf                   @rpmforge
hondain
Post by hondain »
11 rpms Thanks
Nagios XI 5.3.2
CENT-OS as vm host
sreinhardt
-fno-stack-protector
Post by sreinhardt »
You're welcome, I am not sure how readily available those are for ppc, but if you can find those and probably the epel rpms (if they are not already compliant) you should be pretty much ready to go, aside from potential modifications to the scripts to ignore yum installs that you have already done, but we can work through that as it comes.
hondain
Post by hondain »
We have install all the packages need support now ?
Nagios XI 5.3.2
CENT-OS as vm host
Post by slansing »
Can you go into a bit more detail on what you need support/help with now?
hondain
Post by hondain »
I have installed all the packages needed even the one listed above, Now i need someone to help me in installing nagios with out using rpmforge. Last time it was abrist from support, remote in and worked with me.
Nagios XI 5.3.2
CENT-OS as vm host
Post by slansing »
Closing this thread due to opened ticket.
